Oops!!! I missed your reply somehow. Not because it was long but did not see that
Thanks for a detailed explanation
Its a bad driving habit in me that I tend apply clutch before brake (always) and some times end up in only applying clutch since the need to apply brake do not arise - Whether its bad patch of road or passing through crowded places where people are on the road and cross randomly. I know its wrong and trying to correct it from now on.
When there are other passengers the car, I would keep the engine on (idling) and AC ON so that they are comfortable. This happens in ATMs or when we want to buy something from roadside shops etc. I am interested to hear your comments
Hi autosafari ! better late than never.
Well it happens, many people do the same, most of the guys think that the engine will stall when they apply brake, without applying Clutch.
Which is not the fact.
This is all depends upon the speed of the vehicle, the gear you are riding in, and the distance to stop.
Lets Consider & try this out by your own
On a highway drive When riding in 4th, 5th gear, with speed in the range of 90-100 km you can apply brakes gradually, without even touching the clutch, the speed will come down slowly, and engine will work as normal, Beyond certain point you will feel resistance from the engine, in that case apply Clutch and downshift.
Many a times you get away with only applying brake for short period and then you can resume in the same gear.
Riding in City traffic- in Bumper to bumper traffic, yes I agree you need to press clutch Often, but still you can reduce the frequency. Try out these things-
Maintain sufficient distance with the vehicle ahead of you.(Let the vehicle behind you CRY, let him keep honking- for that 3-4 feet distance he wants you to move)
Never accelerate in b2b traffic, just put the car in first gear , release the clutch slowly, the car will move without accelerating.Then you can accelerate slowly as per the need.
First apply brake, and if required then clutch.
Another Reason most of the guys use Clutch more than brake to control speed,
We use the same foot for accelerator and Clutch. Remember your initial days of driving, the time when you was learning the driving.
At that point of time, you must have used clutch and accelerator more, since you must be under impression that the engine will go off if i remove my foot of accelerator, which is not the case.That habit remains with you!
And some people are lazy, they don't want to do exercise with the right foot, and they use the clutch to control speed.
