drivetech4, could you please tell in simple terms whether actually FE decreases if you idle in between or whether FE increases if you idle (running in neutral)
To avoid confusion, please consider only FE here and do not mention about the loss of control and stability while running in neutral down a slope
Well happy to answer your query- The more time you keep you car at Idle, the FE will drastically go down.
![Confused [confused] [confused]](https://www.theautomotiveindia.com/forums/images/smilies/Confused.gif)
Running in neutral is not called idling,
and this should be avoided too.(will come back to it)
Idling means your car is stationery and engine is running.
The details-
HERE'S THE RULE OF THUMB: If you're in a drive-through restaurant, long ques at fuel station, Traffic signal with timer,or waiting for someone and you'll be idling and sitting for 10 seconds or longer... turn off your car's engine. Why??
For every two minutes a car is idling, it uses about the same amount of fuel it takes to go about 1.5 km. Research indicates that the average person idles their car five to 10 minutes a day.
Now I am sure Immediate question from many guys will come,
Does starting the engine require more fuel?
For starting the engine more amount of fuel is required, but it is equivalent to the fuel burnt for 10 secs of Idling. If you see a traffic signal showing 90 secs timer, it is advisable to shut the engine off. you will save fuel for 80 secs.
If you are going to be parked for more than 30 seconds, turn off the engine. Ten seconds of idling can use more fuel than turning off the engine and restarting it. And when you start your engine, don't step down on the accelerator, just simply turn the key to start.
Though Idling is recommended for Cold start, you should idle your car at least for 40 secs to a Minute. This is required for engine warm up and Turbocharger lubrication.(specially for diesel car)
Excessive idling can actually damage your engine components, including cylinders, spark plugs, and exhaust systems. Fuel is only partially combusted when idling because an engine does not operate at its peak temperature. This leads to the build up of fuel residues on cylinder walls that can damage engine components and increase fuel consumption.
Frequent restarting has little impact on engine components like the battery and the starter motor. Component wear caused by restarting the engine is estimated to not more than Rs 500 per year to the cost of driving, money that will likely be recovered several times over in fuel savings from reduced idling.
The bottom line is that more than ten seconds of idling uses more fuel than restarting the engine.
These are
not my personal views, this has got scientific study base too.
Now regarding riding in neutral ,sometimes you see a toll post ay around 100 meters away, you are in speed of say 80 kmph, and you shifted to neutral. The car still runs with same speed because of monetum, ithe speed will reduce only if there is gradient, else speed will not go down below 60 kmph till you reach toll post, suddenly you see the speed breaker and press the break hard, consider Tyre wear, break pad wear, without saving in fuel.
Also when you pass over the speed breaker in neutral,It feel more bouncy, since you dont have any control over the car. This may affect the suspension too.( Guys please correct me if I am wrong)
So it is recommended that you gradual reduce the speed, downshift as speed reduces and come to halt, avoid riding in neutral.
