Mom & Sister who always thinks that front brake is a sin and Manage on Rear brakes alone. Hence their stopping distance is always huge.
Actually, front brake is the aid to prevent rear wheel skidding and vice-versa. Just tell them that the rear tyre will soon get bald and a new MRF tyre will cost Rs. 3000. (mom is the only one in the home who is very very conscious in spending
Just joking bro, dont take it serious. BTW, it is very dangerous (esp. on scooters with linking suspension like Activa, Dio, Kinetic Honda, etc) when only the front brake is applied from 45/50 kmph. The front just raises and skids to either of the sides where the scooter is slightly leaned left or right. And it runs to a scary accident.
I experienced this on my Kinetic Honda (the time when I was fully fascinated about it
). It was raining and I was exploring how the brakes and the bike react when applied too much. I applied only the front brake at speed 50 and the wet road and the bald front tyre resulted a skid. I jumped off but Kinetic was fully done, indicators broken, guards bent, mudguard dented, etc all in one front wheel skid, thanks to the linking type suspension!!. From that, I stayed away from Honda scooters (except Aviator, which is the best for me till now).
BTW, I was not aware that CBS can cause Both wheels to skid. I guess CBS is quite useless without ABS.
Even now if I get a bit more energetic, I could hop on my Activa, rip it to some speeds like 50-65 kmph, stand up a bit and apply only the rear brake lever hard. You will hear the *sweet* squeaking sound of both the MRF tyres.
But you could always loosen the CBS' front brake arm a bit (there will be two extensions from the brake arm, you might have seen it) to reduce the amount of braking applied to the front wheel when only rear brake is used.
Disclaimer: I do not encourage/promote unsafe and insane riding in public roads.
So I guess as per your suggestion I will delay installing CBS and stay stock for now.
Yeah, now only had a conversation with my mechanic about this CBS.
He told that it can be fitted and the components alone costs about Rs. 1500.
And he charges about Rs. 1000 to fit them for me personally (he is my primary and trustworthy mechanic so he costs sensible to me). So around Rs. 1300 for labour.
1500+1500=3000 just for a system which would make both the wheels skid.
I personally won't do it, instead I will train my hands to be more precise than CBS system.
Bhvm bro, you could teach them to use front brakes instead of spending 3k.
No offence bro.
It will be useful and easy for them to ride any scooter after learning how to use both the brakes instead of using only the rear brake with CBS equipped.
Thank you.
