Alloy Wheels Discussions and Show Off
The MGA guy suggested that if I wanted to go for alloys, I should go for one of these. Both are 14" as I an not intent on changing the tyres. He suggested I go for the lower one (sorry for the yellowish snap) as it had lessed spkes and would be easier to maintain. Cost 22.5K for 5 wheels. I had almost ditched the thought but his suggestion brought the consideration back intop my head. What do you think?
Note: though I know MGA uses Neo alloys, I couldnt locate this model in Neo's catalog
Ameyan
Is there any ways to wheel balance alloy wheels by placing weights behind the rim rather than at face which spoils the look?
Also had anyone gone for Momo rims ,wondering if they are strong enough to take abuse here.
Mangalore
AFAIK the balancing weight is always placed at the back of the rim for alloys. The outer balance is placed near the inside edge where the rim ends and the inner balance weights are placed just behind the front facia of the rims. the following image would help you understand it better.Hope the info helps.Regarding Momo wheels i think they should be fine.
Guys,
I found out that the alloy wheels offered by Maruti through their dealerships is made by Enkei. They are significantly lighter than the same design alloys available aftermarket. So, the steel rim I am told is about 10kg where as the Neo alloys are 7.8kg and the Enkei ones are 5.4kg.
In light of this, please suggest which alloys I should go for from these photoshopped pictures. The last one, of course is stock as is currently. I found the 10 spoke design to be marginally lighter than the others. Its colour is also physically darker, so more closer to the colour of my car. However, I thought the flat spoked one more elegant.
Note I am trying to go for elegance rather than a sporty look to go with the otherwise impression of the car. However, I havent made up my mind up at all
Ameyam
chennai
Guys,
Ameyam
Hi Ameyam,
You can try HRS (Hijuan Racing Series). I had used them on my palio for 4 years (about 50K kms) and currently using the same set on my eon. They are good and reliable. Since you want elegance, try wheels with multiple spokes like the ones in pics. Check the following link, select a wheel of your choice and check whether the dealer can source them.
http://www.alloywheelsindia.com/#
Cheers[;)]
Though originally I was considering pic2, I dropped it because the stock Renault Duster tyres are the same, so that design is very common. Its between the 1st and 3rd pictures, if at all. I was leaning towards the third because its not very common of the streets. Only thing, the mspaint work I did resulted in that design ending up slightly larger than it actually will be- mire like 15" size instead of 14".
But most are suggesting not to go for alloys as the expenditure doesnt justify the benefits. So I am really thinking of dropping the idea
Ameyam
Karthik,
more than the wheels you posted, I liked these for saimag.
They are more like the stock wheels that are available abroad with the Swift Sport and arent very common here.
Only quesy, my tyres are 165/80r14. That means the width is 6.5" whereas these are 6" wide. When I select 6.5" in the selector, they dont have any wheels. What am I missing?
Ameyam
Am going for the one in the pics above that is said as "new". Its a simple classy design & will be easy to maintain. Its a 5" wide rim meant for the celerio, can take my existing 165 wide tires & 175 wide in the future if i choose
Ameyam
Guys, have a query- will installing alloys reduce the life of my suspension? had someone telling me this today. Believe he was referring to an install where the wheels are not properly balanced & aligned. Just asking to be sure
Ameyam
Hoshiarpur, punjab
Ameyam
No dear , alloys actually will improve the performance. good branded alloys mostly lighter than steel rims ,which means less load on engine , improve fuel efficiency. Alloys helps to reduce the heat generated by brakes. Alloys are more suitable for tubeless tyres than steel rims .
Benefits will be only if you choose right size and width for your car, otherwise it will damage your suspension in the long run.
Hmm.. i have selected 5" width rims for my 165 & 175 in future tires. That person was telling me alloys wont take these tires but he didnt know that i had done thr research. I am going for OEM alloys (MGA alloys are of Enkei make) which i am told are 5.4kgs whereas the steel rims are 11kg for R14
Ameyam
Hoshiarpur, punjab
Ameyam
yes 175 section tyres can be fitted easily on 4.5J to 6J alloys. you can choose from aftermarket brands if you want good looks too, otherwise go for OEM.
if you want to use all 5 tyres with rotation then go for set of five alloys, and if spare tyre is only for emergency then you can save money by purchasing only 4 alloys.
I noted that alloys payback for themselves when its time to sell your car. They added 10k to the price of my old Wagon R. Based on current prices, thats about half of their cost.
I did my research some time back. HJust sharing my experience
For 165/80R14 (existing tires)- 4.5" to 5.5" rims
For 175/70R14 -5" to 6" rims
For 185/65 R14- 5" to 6.5" rims
Originally started with looking at the OEM rims. Then I went to Neo on the suggestion of fellow TAIians. Though Neo's designs look good on paper, physically, they dont look that classy. Further, my car is grey colour, so black and red trim alloys dont work. I have to look for silver metallic and hyper-silver finish alloys. Their intricate designs will be difficult to maintain. Further, the Neo vendor was hell-bent on selling me 5.5" rims and was also recommending a tire upgrade to wider tires. I noticed later that he didnt have too many options in 5".
I checked with separate a tire dealer and the buyback offered for my 165/80R14 Bridgestones 1600km old is paltry. In fact, the dealer himself suggested to keep the existing tires for that reason.
Rather than spend almost the full amount for newer wider tires, I decided to retain the existing tires that do ok for daily use. Also, my early running is just under 10000km. So, I will be looking at a tire replacement atleast 2.5 to 4 years down the line by which time I may even consider moving on to a new car. So rather than plan too far down the line, I need to consider current tire and may be one size larger only
Not impressed with what I was getting at Neo, I went back to OEM and then noted that the alloys they had were in two rim width sizes- 5.5" and 5". I really liked the 5" rim, the lower rim in this picture, that is meant of the top end Celerio. Its a bit plain but classy and doesnt have the difficult to maintain intricate designs. In 5.5", I liked the upper design but was not sure that I should put it on the 165 tire and whether there will be issues in cornering. Another advantage of asking the OEM to fit the alloys is that they will only fit company approved sizes and in case of any issues, there is a one point insurance claim. I will obviously buy 5 alloys so I dont need to remove and install tires at rotation and I will also ensure that they are balanced and aligned at the time they are installed even if the A.S.S says it isint required
http://www.theautomotiveindia.com/f...-discussions-show-off-img-20141124-wa0000.jpg
So right now, I have asked the showroom to obtain the 5" alloys without paying any advance. They were most willing to oblige because alloys are fast moving products for them, so if I dont purchase, someone else will. I just want to know whether my decision is correct.
In the meantime, I am also wondering whether to purchase R15 tires and matching alloys instead
Ameyam
