Re: Nokia Lumia Series Smartphones Discussions and Experiences
An update from my friend who is using 820 for 6 months.
Fell down thrice. Nothing happened. Sturdy and good hardware !
Thanks for the link
Translated to English
"After the Lumia 920 last fall, mid-May announced the Windows Phone manufacturer to lead a new model: The Lumia 925 Since it's on the market today. The Newer is thinner, narrower, smaller and even lighter. It also has an improved camera and new software applications such as an intelligent photo app. What are the new features and how the Lumia 925 is different from the Lumia 920, you learn in this test.
Interested parties who purchase the Windows Phone to get included not only the device, but also a male-male microUSB cable. This is sufficient for simple data exchange between the Lumia 925 and Windows computers. If you want more, you need the free application from Microsoft. The power supply unit formed of the adapter and cable. With its new flagship product, Nokia provides with a good pair of headphones with different sized buttons. Of course, we have not dared to compare it with high end headsets. 's Calls for the possibility sufficient.
The back is made of rubberized material surrounded by a matte aluminum frame, which also serves as an antenna. The display on the front side is protected by a rounded at the edges 2 of Corning Glass gorilla. The effect of seamlessness not only looks good but also feels great when we pass it with your fingers. The look is timeless ever: How can the design of the Nokia devices now describe. The Lumia 925 looks simple, yet powerful in its presence. Haptic processing, pressure points of each key and value are compelling. Move the phone back and forth, so nothing wobbles, everything makes a solid impression. The Lumia 925 is 129mm high and 8.5 mm thick, it weighs 139g. In spite of this size, the one-handed operation is no problem, because the operating system controls are built over a large area. Only typing, whether vertical or horizontal, to be done with two hands. The Nokia Lumia 925 is available in three colors: light gray, dark gray and white
The display is 4.5-inches diagonally in size, which are 114mm. It is an organic display that goes by the name "Nokia Pure Motion HD +". It is highly sensitive and allows operation with a glove. It also operates at 60 Hertz, reducing the fibrillation - a low frequency which was not a problem so far in the past. The resolution is WXGA, which is the highest vector at a Windows Phone. Important for the display sharpness, however, the pixel density. This is the Lumia 925 at 331ppi. That's more than you need. Other factors of displays are excellent: The black level is best in class, the viewing angle is stable, the colors are very bright but a little oversaturated. "
Maker Nokia
Board Catwalk
Model RM-892
Dimensions 129mm high x 70.6 mm wide x 8.5 mm thick at 139g
battery 2,000 mAh
Platform Microsoft Windows Phone OS 8 (Bulid: 8.0.10327.77)
Processor Qualcomm Snapdragon S4 MSM8960 Plus (Krait 200)
Power 2 × 1.500MHz
Qualcomm Adreno 225 graphics unit
Short memory 1024MB
Internal memory 16GB (32GB Vodafone exclusive)
External Storage not available
Cellular radio system GSM / Quad Band | GPRS / EDGE / UMTS / HSPA + with 42Mbit / s / LTE with 100 Mbit / s over 800MHz, 1.800MHz and 2.600MHz
Interfaces Bluetooth 3.0, NFC, Wi-Fi 802.11 abgn, three Probes
SAR value of 0.81 W / kg
Display Technology (OLED Nokia Pure Motion HD +)
Display Size 4.5-inch (114mm)
Display Wide Extended Graphics Array resolution (1,280 × 768 pixels, 5:3)
983,040 pixels at 331ppi pixel density
Primary Camera 7.99-megapixel (3,264 × 2,448 pixels) Aperture f/2.0
Secondary camera 1.2 megapixel (1,280 × 960 pixels)
Type microSIM SIM card
Translated using google translator
