Thanks mate. So fog is good to go. So as per you which h4 led for headlights would be good.
As you have already ordered would recommend to try them, as in LED technology it lot more depends on how the reflectors are complimenting the LED. Even a low powered LED can perform better if it gets the sweet spot of your reflectors.
I can guide you choosing the right LED for future purchases as whatever we have tried till date are a bit costly. Also, below details is my own assumption and i can be wrong, below suggestions is based on my experience with these lights.
Things to consider:
1- Color temp you are choosing - 4300 - 5000K is ideal for visibility ( now a days there are LED's which have three color chips used which you can switch on the go. )
2- Chip used - try avoiding COB and look for at least CSP chip for budget LED's. COB chips are greater in size which find it difficult to find the sweet spot of reflector and behave more like flood beam. Also, tend to decay soon, Initially they will light up great and slowly and gradually output will decrease. In comparison the CSP chip are smaller in size and can acquire good amount of light from single spots.
Not mentioned CREE for the reason for end user/customers it real hard to check if the CREE chip is original from USA or made in China. The china ones are also good the power rating is different to original ones.
As per my feedback, Luxenon MZ is the best chip i have tried but costs go high and life of all these leds are almost same due to not getting proper heat sink.
Few links which i found can be a good option is below. Please note have never tried these but looks promising to me.
https://www.aliexpress.com/store/pr...B4-50W-5800LM-3000K/2677154_32841906344.html?
https://www.aliexpress.com/item/2PC...4-HB3-H11-H1-9005-Car-Light/32885313879.html?
Hope this helps
