What's Hot in Mobile Phone Industry?
Vivo Y76s (t1 version) launched
The Vivo Y76s (t1 version) features a 6.58-inch LCD waterdrop notch display that offers a Full HD+ resolution of 2408 x 1080 pixels, a 60Hz refresh rate, and a 180Hz touch sampling rate. The device runs on Android 12 OS and FunTouch OS UI. The power button located on its right edge is integrated with a fingerprint scanner.
The Dimensity 700 powers the Vivo Y76s (t1 version). The mid-ranger comes in a single model that offers 12 GB of LPDDR4x RAM and 256 GB of UFS 2.2 internal storage. For more storage, it has a microSD card slot onboard. It packs a 4,100mAh battery with 44W fast charging. It measures 163.84 x 75.00 x 7.79 mm and weighs 175 grams.
The phone is is priced at 1,899 Yuan .
Infinix Hot 20 Play launched in India
The Infinix Hot 20 Play houses 6.82-inch LCD display with a punch-hole design. It delivers an HD+ resolution of 1640 x 720 pixels, a refresh rate of 90Hz, and a touch sampling rate of 120Hz. It has an 8-megapixel front camera with an LED flash and a 13-megapixel dual-camera system with a quad-LED flash on the back. A fingerprint scanner is also available on the rear shell of the device.
The phone is powered by the MediaTek Helio G37 chipset and 4 GB of LPDDR4x RAM. It also offers 3 GB of virtual RAM and 64 GB of internal storage. The phone runs on XOS 10 6.0-based Android 12 OS.
It offers features like aerospace-grade cooling material, Dar-Link Engine 2.0, LinkPlus 1.0, and Erdal Engine 3.0. The phone comes with 6,000mAh battery that supports 18W charging via USB-C. The other features that are available on the Hot 20 Play include a dedicated microSD card slot, DTS Audio support, and a 3.5mm audio jack.
It is at Rs 8,999
Realme 10 Pro, 10 Pro+ launched in India
The Realme 10 Pro sports a 6.7-inch LCD display with an FHD+ resolution and offers 120Hz refresh rate and 240Hz touch sampling rate. Under the hood, the smartphone equips a Qualcomm Snapdragon 695 SoC, up to 12GB LPDDR4x RAM, and up to 256GB UFS 2.2 storage. It packs a 5000mAh battery with support for 33W fast wired charging. The smartphone runs on Android 13 based Realme UI 4.0 out of the box. Additional features include side-mounted fingerprint sensor, dual stereo speakers. Connectivity options include dual-band Wi-Fi, 5G, NFC, GPS, USB-C port and Bluetooth 5.1.
The 10 Pro+ sports a 6.7-inch curved AMOLED display with an FHD+ resolution and offers 10-bit colour depth, 120Hz refresh rate, and 950 nits peak brightness. The device can cover 100% of the DCI-P3 colour gamut. It packs a 5000mAh battery with support for 67W fast wired charging. The smartphone runs on Android 13 based Realme UI 4.0 out of the box. Additional features include in-display fingerprint sensor and dual stereo speakers. Connectivity options include dual-band Wi-Fi, 5G, NFC, USB-C port and Bluetooth 5.1.
The price of Realme 10 Pro+ 5G starts at Rs 24,999 for the 6GB RAM + 128GB storage variant, Rs 25,999 for the 8GB RAM + 128GB storage model and Rs 27,999 for the 8GB RAM + 256GB storage variant.
The Realme 10 Pro 5G is priced at Rs 18,999 for the base 6GB RAM + 128GB storage model. The 8GB RAM + 128GB storage variant is priced at Rs 19,999.
Vivo Y100 launched in India
The Vivo Y100 runs on Android 13 based FunTouchOS 13 and sports a 6.38-inch HDR10+ AMOLED display with a refresh rate of 120Hz, peak brightness of 1300 nits and a 20:9 aspect ratio. The phone is powered by an octa-core MediaTek Dimensity 900 chipset, paired with 8GB of RAM, 128GB UFS 2.2 storage and ARM Mali-G68 MP4 GPU.
It features a triple rear camera setup with a 64-megapixel f/1.79 main sensor, a 2-megapixel f/2.4 secondary camera, and a 2-megapixel f/2.4 tertiary lens. There is 16-megapixel front facing camera which is housed in a waterdrop notch at the top of the front display.
The device packs a 4500mAh battery with 44W FlashCharge support. Connectivity options include dual-band Wi-Fi, Bluetooth 5.2, USB-C port and GPS. There’s an in-display fingerprint sensor for biometrics. The smartphone is priced at Rs 24,999 for the sole 8GB+128GB variant
iQOO Z7 5G With Dimensity 920 SoC launched in India
FireShot Capture 193 - iQoo Z7 5G Price in India Revealed Ahead of Launch in India on March _ ...png
The iQOO Z7 5G features a 6.38-inch AMOLED display bearing an FHD+ resolution and a waterdrop notch. It comes with a 90Hz refresh rate, 1,300 nits peak brightness and HDR10+ support. There is also an in-screen fingerprint scanner. The smartphone has a boxy design and a rectangular rear camera module.
It has dual rear cameras. The setup consists a 64MP ISOCELL GW3 primary sensor with optical image stabilisation as well as electronic image stabilisation. There is a 2MP depth lens and on the front, the device features a 16MP selfie snapper. The smartphone packs 4K video recording and Vlog movie mode.
It is equipped with a MediaTek Dimensity 920 processor based on 6nm process. It is offered in 6GB and 8GB RAM options with both packing 128GB onboard storage. The smartphone draws its power from a 5,000mAh battery unit with support for 44W fast charging.
It costs Rs 18,999 and Rs 19,999 for the 6GB and 8GB RAM variants.
Asus Zenfone 10 launched with 144Hz display
The Asus Zenfone 10 sports a 5.9-inch AMOLED display with a 20:9 aspect ratio, 1100 nits peak brightness, HDR10+ support, and a refresh rate of up to 144Hz. However, Asus says that the 144 Hz refresh rate can only be enabled in Game Genie while playing mobile games. The panel is protected with Gorilla Glass Victus.
The phone is powered by Qualcomm’s Snapdragon 8 Gen 2 SoC. It gets up to 512GB of UFS 4.0 storage and up to 16GB of LPDDR5x RAM. On the back, there are two cameras with a LED flash along with support for the six-axis hybrid gimbal stabiliser 2.0. It packs a 4,300mAh battery with support for 30W fast charging and 15W wireless charging. It also gets multi-magnet stereo speakers with Dirac Audio, Hi-res audio and a 3.5mm audio jack.
The handset comes with an IP68 rating for dust and water resistance. The connectivity features include 5G SA/NSA, 5G, Wi-Fi 802.11ax 6E or Wi-Fi 7 depending on regions, Bluetooth 5.3, GPS/GLONASS/Beidou, Galileo(E1+E5a), QZSS(L1+L5), NavIC(L5), USB Type-C, and NFC.
It is offered in 3 variants, the base 8GB RAM + 128GB storage variant is priced at EUR 799, the 8GB RAM + 256GB storage variant is priced at EUR 849 and the top-end 16GB RAM + 512GB model is listed at EUR 929.
Jio Bharat affordable 4G Feature Phone with UPI support launched in India
Reliance Jio has launched new Jio Bharat Phone. This budget-friendly feature phone aims to bridge the digital divide and provide affordable connectivity to millions of Indians.
RJio has launched Jio Bharat with the objective of empowering every Indian with the power of digital services, especially those who cannot afford a smartphone. The phone aims to make high quality and affordable data will be within the reach of the common man.
The Jio Bharat Phone comes with a 1.77-inch QVGA TFT display. The budget-friendly phone supports HD calling, UPI payment using JioMoney, access to OTT services like Jio Cinema. The phone is equipped with a removable 1000mah battery that can last for up to 24 hrs on single charge. There’s a 3.5mm audio phone jack for connecting earphones, a 0.3MP camera for clicking pictures, a torch, FM radio and an expandable storage.
Like the other Jio phones that we’ve seen in past, Jio Bharat is also a Jio SIM locked phone which means you have to insert the Jio SIM card in it before using. The phone supports 23 Indian languages and comes in two series- JioBharat V2 and JioBharat K1 Karbonn.
JioBharat V2 is company’s in-house built phone while the K1 Karbonn has built using Jio Bharat platform by the Delhi-headquartered company called Karbonn. Both the phones come with pre-installed Jio apps.
One of the key features of the Jio Bharat Phone is its support for 4G VoLTE, allowing users to make crystal-clear voice calls over Jio’s extensive 4G network.
The Jio Bharat Phone is priced at affordable Rs 999 making it one of the cheapest internet-enabled phones in the market. Jio will start beta trials for the first 1 million Jio Bharat phones from July 7 onwards across 6,500 tehsils in India.
Interested customers can purchase the Jio Bharat Phone by visiting Reliance Digital stores, Jio retail outlets, and other retail outlets across the country.
Along with the device, Jio is offering attractive prepaid plans tailored specifically for Jio Bharat Phone users. These plans include a combination of voice calls, data benefits, and access to Jio’s suite of apps.
Financial Express
Motorola Razr 40 series launched in India
Motorola has debuted the Razr 40 series flip foldable phones in India, including the Razr 40 and the Razr 40 Ultra. The Moto Razr 40 also happens to be the cheapest foldable smartphone in India. The Razr 40 Ultra on the other hand, competes with the Oppo Find N2 Flip and the Samsung Galaxy Z Flip 4.
The Motorola Razr 40 Ultra comes in a single 8GB + 256GB variant priced at Rs 89,999, in Viva Magenta and Infinite Black colour options. While the pre-booking for the smartphone is already live, it will be available for purchase on July 15 via Motorola India channels and Flipkart. ICICI Bank card users can get an instant discount of Rs 7,000 on the handset, bringing the price down to Rs 82,999.
The Motorola Razr 40 Ultra sports a 3.6-inch external cover display which is a pOLED screen with a 144Hz refresh rate, HDR10+ support, 1100 nits peak brightness, 1056 x 1066 pixels resolution with 413 ppi and Glass Victus protection. Then there is a 6.9-inch FHD+ pOLED folding display with a 165Hz refresh rate, HDR10+, 1400 nits peak brightness and 1080 x 2640 pixels resolution.
It is powered by the Snapdragon 8+ Gen 1 processor with Adreno 730 GPU, 8GB of LPDDR5 RAM with 256GB of UFS 3.1 storage. It packs a 3,800mAh battery with 33W TurboPower fast charging and 5W wireless charging support. The device is IP52 rated also.
For optics, you get a 12MP f/1.5 primary camera with OIS, and a 13MP f/2.2 ultra-wide autofocus camera. There’s a 32MP front camera for selfies and video calls. Connectivity options include 5G, dual 4G VoLTE, Wi-Fi 6E, Bluetooth 5.3, USB Type-C port, and NFC. It is further equipped with stereo speakers, and Dolby Atmos. Lastly, the Razr 40 Ultra runs on Android 13 with Moto MyUX UI on top.
The Motorola Razr 40 also comes in a sole 8GB + 256GB variant priced at Rs 59,999. It will come in Sage Green, Summer Lilac, and Vanilla Cream colour options. The pre-booking for the smartphone is already live, and it will be available for purchase on July 15 via Motorola India channels and Flipkart. ICICI Bank card users can get an instant discount of Rs 5,000 on the handset, bringing the price down to Rs 54,999.
Motorola Razr 40 has a 1.5-inch OLED cover display with a resolution of 194 x 368 pixels, 60Hz refresh rate, 282 ppi, Gorilla Glass Victus protection and peak brightness of 1000 nits. The handset will arrive with a 6.9-inch main OLED display that will have HDR10+ support, 2640 x 1080 pixels resolution, 10-bit colour, 1400 nits peak brightness and a 144Hz refresh rate.
The phone is powered by Snapdragon 7 Gen 1 processor and comes with 8GB of LPDDR4x RAM and 256GB of UFS 2.2 storage. The handset runs on Android 13 OS and has a side-mounted fingerprint sensor.
The back of the device will include a dual-camera setup. The smartphone’s primary camera module includes a 64MP f/1.7 main sensor with OIS, PDAF, while the secondary lens is a 13MP f/2.2 ultra-wide shooter. On the front side, the handset boasts of a 32MP f/2.4 camera. The device packs a 4200mAh battery which offers 30W Turbo wired charging support and 5W wireless charging support.
The device has dual-SIM 5G support, Wi-Fi 6E, Bluetooth 5.3, NFC and a USB-C port for charging. It offers stereo speakers and an IP52 rated water repellent coating also.
Themobileindian
Samsung Galaxy M34 5G launched in India
The Galaxy M34 5G is equipped with the Exynos 1280 SoC, the same chip found in the Galaxy M33 5G. It comes in two variants: one with 6GB RAM and 128GB storage, and another with 8GB RAM and 128GB internal storage. The phone runs on Android 13 out of the box, featuring the OneUI custom skin. Similar to other recent mid-range Samsung phones, the Galaxy M34 5G ensures four years of OS updates and five years of security updates. It is powered by a 6000mAh battery and supports 25W fast charging.
It boasts a triple rear camera system comprising a 50-megapixel image sensor with OIS support. It also includes an 8-megapixel ultrawide camera and a 2-megapixel depth or macro sensor. For selfies and video calls, there’s a 12-megapixel front-facing camera. Samsung has introduced Monster Shot 2.0 on this smartphone and has also added Fun mode and Nightography.
It is priced at Rs 17,999 for the 6GB RAM + 128GB storage option and Rs 18,999 for the 8GB RAM + 128GB storage option. Pre-booking for the device starts today, July 7, and the sale will commence during the Prime Day event starting on July 15. The smartphone can be purchased from both Amazon.in and Samsung’s official channels. The introductory prices for the Galaxy M34 5G are Rs 16,999 for the 6GB RAM variant and Rs 18,999 for the 8GB RAM variant.
Vivo Y27 5G with Dimensity 6020 SoC launched
The Vivo Y27 5G features a 6.44-inch LCD display bearing a waterdrop notch. It offers an FHD+ resolution and 600 nits peak brightness. The power button doubles up as a fingerprint scanner. The back panel has a square camera module.
On the imaging front, the Vivo Y27 5G has a dual rear camera setup of a 50MP main sensor paired with a 2MP secondary bokeh lens. The device features an 8MP front-facing selfie snapper.
The phone is equipped with a MediaTek Dimensity 6020 processor. It is offered in 4GB and 6GB RAM options along with up to 6GB virtual RAM features. Both variants pack 128GB onboard storage. The smartphone draws its power from a 5,000mAh battery unit with support for 15W fast charging. Software-wise, it runs on a Funtouch OS 13 based on Android 13.
Connectivity options on the Vivo Y27 5G include 5G, a USB-C port, a 3.5mm jack, WiFi, Bluetooth, and NFC. The Vivo Y27 5G is offered in Mystic Black and Satin Purple colors. The brand is yet to announce the pricing and availability of the smartphone. At present, the Vivo Y27 5G pricing is yet to be revealed.
Honor Play 40C launched with 90Hz display, Snapdragon 480 Plus
The Honor Play 40C features a 6.56-inch LCD waterdrop screen with an HD+ resolution of 1612 x 720 pixels and a 90Hz refresh rate. It also offers a 90Hz touch sampling rate and 70% NTSC color gamut.
It features a 5-megapixel front-facing camera for high-quality selfies. At the rear, it houses a 13-megapixel camera with an LED flash. The device comes preinstalled with MagicOS 7.1 UI-based Android 13.
Powering the Honor Play 40C is the Snapdragon 480 Plus chipset and a massive 5,200mAh battery with 10W charging. The device comes with 6 GB of RAM and 128 GB of internal storage.
The phone comes with other features, such as dual SIM, 5G, Wi-Fi, Bluetooth, GPS, NFC, a USB-C port, a side-facing fingerprint scanner, and a 3.5mm audio jack. With a thickness of just 8.35mm and weighing 188 grams.
It comes in the 6GB+128GB variant only and is priced at 899 Yuan .
Infinix Hot 30 5G goes on sale for Rs 12,499 (~$152), packs 6.78-inch 120Hz display, 6,000mAh battery, 50MP main camera
The Infinix Hot 30 5G is fitted with a 6.78-inch Full HD+ LCD punch-hole display with a resolution of 2460 x1080 pixels and a 20.5:9 aspect ratio. Also, the display offers a 120Hz refresh rate, a 240Hz touch sampling rate, and a peak brightness of up to 580 nits. For security, it has a side-facing fingerprint scanner.
It features the MediaTek Dimensity 6020 7nm processor and comes with 4 GB / 8 GB RAM variants, up to 8 GB of virtual RAM, and 128 GB of built-in storage. It runs on XOS 13, which is based on Android 13. It packs a 6,000mAh battery that supports 18W charging.
The phone offers an 8-megapixel camera with dual LED flash. Its back panel features a 50-megapixel primary camera, an AI lens, and a quad-LED flash unit. For audiophiles, it offers features like a 3.5mm audio jack and dual stereo speakers. It offers other features, such as an IP53 rated chassis, 5G (n1, n3, n5, n8, n28, n38, n40, n41, n77, and n78 bands), Wi-Fi 802.11ac, Bluetooth 5.1, GPS, and a USB-C port.
It is priced at, 4 GB RAM + 128 GB storage for Rs 12,499 and 8 GB RAM + 128 GB storage for Rs 13,499
HTC U23 launched, Check pricing, specs & availability
After unveiling the HTC U23 and U23 Pro back in May, the brand has finally started selling the U23 in Taiwan. The device comes with standout features like an FHD+ OLED display, a triple camera setup, and a Snapdragon 7 series processor.
FireShot Capture 245 - HTC U23 launched, Check pricing, specs & availability - Gizmochina_ - w...png
The HTC U23 is offered in a single 8GB RAM + 128GB storage variant which costs TWD14,990 ($480). It is available to purchase from the brand’s website and comes in two color options: Roland Purple and Aqua blue.
The HTC U23 features a 6.7-inch FHD+ 120Hz OLED display with Gorilla Glass Victus protection, making it resistant to scratches and impacts. Running on the Qualcomm Snapdragon 7 Gen 1 processor, the HTC U23 comes with 8GB of RAM and 128GB of internal storage. It packs a 4,600mAh battery with support for 30W fast charging, 15W wireless charging, and reverse charging. The device is IP67 certified, offering water and dust resistance.
The main camera setup includes a 64-megapixel lens, an 8-megapixel lens, and a 2-megapixel lens, offering various shooting modes like professional, night scene, portrait, wide-angle shots, beauty adjustments, time-lapse, and slow-motion photography. The main camera also supports 4K video recording with Electronic Image Stabilization (EIS). On the front, there’s a 32-megapixel camera with beauty adjustment, portrait mode, night scene mode, and time-lapse capabilities. The device has dual speakers and a 3.5mm audio jack. It also supports Wi-Fi 6 for improved connectivity.
Gizmochina
Samsung Galaxy Z Fold 5 launched with improved hinge, Snapdragon 8 Gen 2 SoC
Samsung today held its annual Galaxy Unpacked event in Seoul, South Korea. The event witnessed the launch of several new products, including the most awaited Samsung Galaxy Z Fold 5. Debuting as a minor upgrade over the Galaxy Z Fold 4, the foldable brings a new hinge that lets it fold flat. You also get the Snapdragon 8 Gen 2 for Galaxy chip from the flagship S23 series. Here are the details.
If you have seen the Galaxy Z Fold 4, you have also seen the Galaxy Z Fold 5. The camera module on the rear is the same as last gen model and so is the ingress protection (IPX8). What is not the same on the phone is the hinge. The company has opted for a new teardrop-shaped hinge that allows it to close flat. It will also let you use the phone at any angle. The Z Fold 5 measures 13.4mm thick when closed whereas the Fold 4 was 14.2mm thick. It has also lost some weight and is 10g lighter than the Z Fold 4, which weighs 263g.
The display on the phone hasn’t changed much either. The outer display measures 6.2 inches and offers a 2316x904px resolution. The AMOLED panel has a 120Hz adaptive refresh rate. On the inside, you get a 7.6-inch Dynamic AMOLED 2X with 2176x1812px resolution, and an adaptive 120Hz refresh rate. The main screen can reach a peak brightness of 1,750 nits.
The new Galaxy Z Fold 5 is powered by the Snapdragon 8 Gen 2 Mobile Platform for Galaxy but that’s about all. The camera system remains unchanged. There’s a 50MP primary shooter on the rear, accompanied by a 50MP wide-angle sensor, and a 10MP zoom camera. For selfies, you get a generous 10MP shooter on the cover screen and a 4MP under-display camera on the inside.
Samsung Galaxy Z Fold 5 is fueled by the same 4,400mAh battery with support for 25W wired and 15W wireless charging. It runs Android 13-based One UI 5.1.1 on the software front with a redesigned taskbar, a two-handed drag-and-drop feature, among other features. The S Pen for the foldable has also been made 40% thinner.
The Samsung Galaxy Z Fold5 can be pre-ordered in select markets today and it will start shipping from August 11. The phone is offered in Icy Blue, Phantom Black, and Cream. Talking about the price, Galaxy Z Fold 5 comes priced at $1,799 for the 256GB variant, $1,919 for the 512GB version, and $2,159 for the 1TB storage option.
Gizmochina
iQOO Z7 Pro launched in India
The iQOO Z7 Pro looks like a Vivo S17 series device because it is one. It has the iconic ring LED flash on the rear and a thin and light design. The phone is thin at 7.36mm and weighs 175g. Its front and rear are curved to provide a comfortable grip.
The handset is built around a 6.78-inch curved AMOLED display with a centered punch hole and Schott Xensation glass protection. The 10-bit panel has a resolution of 2400 x 1080 pixels (FHD+), 388 PPI, 120Hz refresh rate, and 300Hz touch sampling rate.
The smartphone is powered by a MediaTek Dimensity 7200 chip paired with LPDDR4x RAM, UFS 2.2 storage, and a VC liquid cooling system. It boots Funtouch OS 13 based on Android 13. It is equipped with a dual camera setup comprising an OIS-assisted 64MP primary sensor and a 2 MP depth sensor. On the front, it has a 16MP snapper for selfies and video calls.
The device comes with in-screen fingerprint sensor but lacks dual stereo speakers. Connectivity-wise, it offers dual SIM, 5G, WiFI 6, Bluetooth 5.3, GNSS, and USB Type-C. It is backed by a 4,600mAh battery with support for 66W wired charging.
