Re: Which car wash to use confused?
hi thanks for your suggestion.just one more question does a new car needs really waxing?what are products do i need to apply wax & do i need to remove wax during next car wash.if i am applying Meguiar's Ultimate Quick wax Spray how long will it stay?
If your new car has been prepared well by your dealer before delivery, there is no need to wax the car right now. If you wash your car and see the water beading, it will tell you whetehr it needs waxing or not, generally once in four months should be okay, but it depends on what your car is exposed to, whether it is in an exposed or covered parking and so many other external factors.
Since it is a new car, you can keep it in dazzling condition, if you take certain precautions. Wash your car, only if you have to, otherwise waterless cleaners like Optimum no rinse will do the work for you and also get good microfibre towels to wipe down your car. I find that this will reduce swirls to a minimum. Everyday, dust your car with a non scratching brush like Jopasu duster, after which you can finish with a good detailer spray like Meguiars or Mothers. If you are waxing, get hold of good Carnuba wax, either paste or liquid, liquid wax is easier to apply. These are mostly applied by hand using a good foam applicator and wiped off with MF cloth. Instead of wax, you can use synthetic polymer sealants too, like Megs Quik wax or similar preparations. The shine will last for quite some time, which you would have found out by now.
Just do a google search on Car detailing, you will be amazed at the amount of information there. A well detailed car is a pleasure to look at ,though it takes some effort to do that. All the best
