Washing Your Engine Bay - A Step By Step Guide
Moga (Punjab)
Today i washed my Polo's engine bay. I was afraid to the bones but still went ahead with it. While covering alternator and battery with aluminum foil spark came from engine [confused] so i left alternator uncovered. Pics before and after washing.
:please: My two words of advice, if you have big heart then only wash your Polo's Engine Bay.
Thread Starter #33
RANCHI/BOKARO
Spark should not come untill and unless your ignition is in on position. Always Take out the key from the ignition whenever you wash the engine.
Moga (Punjab)
IMO, it is a dumb idea covering with aluminium foil as there is live positive at battery and foil being a conductor and negative everywhere around.
I think you are right but i read somewhere that while washing engine bay cover air intake and alternator with aluminium foil, but not doing it again.[embarass]
deville_56
Even at authorized service centers they simply block the air intake with cloth and spray air-diesel mix (they won't mix, but sprayed together with a attachment like spray paint gun) and sometimes blow dry, sometimes leave in sun. I have never seen someone washing every nook and cover with soap and water [evil]
Thread Starter #39
RANCHI/BOKARO
woow Excellent Thread Sumit Bhai [clap]
hear i can post all my cars engine bay pictures [:D]
MARUTI 800 1986 ENGINE BAY
MARUTI ALTO 2011
HONDA CITY 2005
TOYOTA INNOVA 2006
Adil bhai, spectacular pics. Especially the 800 one. Hats off to your magic.
Guys, the best possible masking for everything is simple plastic. Use polythenes to cover them all. And use rubber bands to strap it. It wont spark, and it won't let water seep in also.
Thread Starter #41
RANCHI/BOKARO
Earlier i used simple waxpol vinyl polish or any other polish to dress the plastic parts of the engine.
Now what i use is Zorrick 88. Wash the engine, let it dry completely, spray zorrick all over. Be careful that the engine is not hot while you spray, Wipe it off. It will leave good shine behind.
MOST IMPORTANTLY, PLEASE DO NOT START THE CAR JUST AFTER YOU HAVE COMPLETED SPRAYING, LET IT DRY FOR ATLEAST 15-20 MINS THEN ONLY START.
One more benefit of zorrick is that rats don't come in your engine bay, once it is sprayed. And zorrick doesn't also attracts dust.
NCR
This is definitely a huge benefit :-)
Dude you are really a brave man. I mean it !!! I had a bad experience cleaning my Ford ikons engine. So since then I have stopped cleaning engine compartments. I only vacuum it with a brush. I gently use a soft paint brush over the injectors and suck the dust off with my karcher vacuum cleaner. Same goes with the battery and other internals. And I religiously clean the engine's oil cap and the oil cap seal from dust and grime. I suck it up with a vacuum cleaner with utmost care so that the dust doesn't fall off inside. I do this every time before topping up my engine oil or giving it for a service . Because I doubt VW service guys would take such care while refilling the engine oil.
And I bought a plastic funnels from china market for topping up the engine oil as well as G13 coolant.
