I have got the camber adjusted on my car. They charge 300 rs per wheel. This is done only on independent suspensions.
They re-weld the hub mounting points on the struts as per the measurement so that hub mounts according to the measurement.
Even caster can be adjusted if there is a slight difference. They just add a washer at the balance rod (stabilizer bar connecting to lower arm). Usually done for older vehicles (sumo, indica, omni, 800 etc). I have also seen them filing the strut mounts so that it can be adjusted accordingly. (Commonly seen on indica's).
Hi
Figoian : You need to get the balancing done on all the wheels, even if there is a slight bend on the rim it will effect the entire suspension system also causes uneven tire wear. The wheel bearings get damaged on long run.
I gues Figo comes with independent suspension at rear rite ? They even align the rear wheels too. (if independent suspension)
