Re: The ‘Urbano Bestia’. My Ford Ecosport 1.5 TDCI Titanium! (20K Service Done)
Hi Vinrvk, welcome to TAI and hope you enjoy the forum and at the same time hope you find the information shared by we fellow members useful at all times.
Regarding the warning message, I recommend you to take a video of the message and escalate it to your nearest Ford service center and ask them to fix it. It is either because of the oil level or a faulty sensor. So far I have seen around 5 vehicles which have suffered with this issue in Ford's Belgaum service center. So I think 5 out of 100 vehicles have this problem![Surprise [surprise] [surprise]](https://www.theautomotiveindia.com/forums/images/smilies/Surprise.gif)
I didn't go for the Ford's signature headlamps with LED DRl as I found them useless at day light, they are hardly visible. I suggest you instead go for DRL fitted in fog light black cover like this one Free shipping, 2x CAR Specific Excellent Led daytime running light DRL for Ford ECOSPORT 2013-in Daytime Running Lights from Automobiles & Motorcycles on Aliexpress.com Do not buy it here, but try sourcing from your local accessory shop. I got them in a local store for around Rs4000/-
Hi Somash, Yup indeed, its always good to share information and get benefited overall.
I have not tried the Aerotwin blades from Bosch, but I have heard they have good and smooth wipe than the average quality of OEM one's. I suggest you go for it if you are willing to change the OEM ones. I have clocked around 27k on my Ecosport but still find the wiper blades doing fine.
Regarding the audio songs, No I haven't faced any issues of indexing. It indexes only when I have updated my Pen drive with new songs/folders or have removed some folders.
Moreover I feel its a software issue and should be easily fixed upon updating or reinstalling the software at your nearest Ford service center.
You can find the LED DRl's I have installed in my headlight here: http://www.theautomotiveindia.com/f...ort-1-5-tdci-titanium-20k-service-done-5.html
But I recommend you to go for the fog light DRl's mentioned above as installing LED strips in headlights is a cumbersome process and you will not like the way the accessory shops rip apart your headlight glass/lens from its body :)
Spot on @ MSN1! Please try these methods above, if it still doesn't work, then reinstalling or updating the software is your ultimate solution to fix this.
hello brother even i am facing this problem till date , my ecosport has run 15k kms, kindly help me how to get this problem immediately because the message is really annoying, also did you fit the led lights which is now available in showrooms.
Guys,
Nice informative thread wrt Ecosport.
Done with 20K kms with Ecoboost.
1. Planning to change wiper blades with AEROTWIn model from Bosch -- any suggestions.
2. Having one issue with the player device, which is very irritating at times.
Sometimes, when the engine is turned OFF & then switched ON, the sync system goes into to indexing mode mainly with USB. Then I need to start with the first song.
But many a times, the system continues with the song where it has stopped. Also tried with pausing before engine OFF - but still problem persists.
Attaching the snapshot of the screen fo rthe version
@ Vj,
can you pls post pics of the lights you've modified. May plan to do in my Ecosport.
Kindly help
@ Vj,
Kindly help
Lets try below method to isolate and find what actually causing the problem,
Ecosport audio system is equiped to play mp3 or songs from CD, pendrive, bluetooth audio
Am not mentioning aux in and radio as those two are different (radio broadcasting doesnt need the same software / app or used to play mp3 and aux in ia simple external player only audio gets feeded to the speaker system .
1. Is it happening with songs from cd player ( yes or no )
2. If songs from cd and mobile played well with out issues then try using a diffrent pendrive and check.
I have used even mobile where it takes and played the song from.where i stoped the engine earlier, and same thing goes with cd
If all failed then its a software issue, dealer can install software and fix the issue.
