Stealth - 2002 Honda Dio
Goa
The headlight on my Honda Dio 2006 model is very poor. So, I was thinking of converting from BA20D to H4 bulb too. Is the Osram bulb good ? How long did it last ?
Also do I have to cut any wires ? Also, do I have to buy a retaining clip and a dust cover ?
Do you have any video that I could refer to? It will be very helpful for me.
Thanks in advance.
Thread Starter #32
Thanks in advance.
Needs wiring cutting. Have to scavenge the old headlight coupler. No harm to original vehicle wiring harness.
Yes, new retaining clip and dust cover needed. Clip can be from any H4 or HS1 headlight unit. I doubt it's available off the shelf. Just wander around a mechanic's place and can easily find one lying around or ask him for an old one. Cap is available off the shelf. Mine is from FZ. That can also be sourced from a mechanic.
No video. I think fully explained in my post here >> Dio to H4
Thread Starter #33
January 2024 - New Tyres
Bought new rims en route to the tyre shop. Got original later generation Dio part with tubeless neck like the previous one.
Rim Set - 42660KZK900 - ₹ 884.00
Bought Apollo for both ends.
Front - Apollo ActiZip S1 90/100-10 - ₹ 1,300.00 (MRP ₹ 1,550.00)
Fresh piece. December 2023 make.
Got a more button type tyre for the rear per his recommendation.
Apollo ActiGrip S5 90/100-10 - ₹ 1,300.00 (MRP ₹ 1,575.00)
December 2023 end make. Even fresher piece.
Condition of old tyres. Alignment issue is clearly evident against the false claim of the mechanic. Front was Ceat Zoom, which lasted 18-20k km and the rear Michelin Pilot Street 13k km.
Changed oil too. Oil change has become a frequent business with the high miles clocked by the Dio, hitting 2-2.5k km in 2-3 months. Oil prices also rising steadily. Bought Shell this time.
Shell Advance AX5 20W40 - ₹ 420.00 (MRP ₹ 428.00)
Replaced rear indicator and brake light bulbs.
Back on the road.
Thread Starter #35
January 2024 - Old Trouble Repeats
Tube connecting inlet pipe to air suction valve cracked again. Cold start and idling will be problematic. Needs choke to start and extra throttle input to prevent stalling.
The issue resurfaced as expected.
The hose cracked again, this time the new hose.
The length was not enough for a temporary cut-paste job.
Got some better-quality fuel hose than the grey ones.
Installed and ready. A wire tag was used in place of the lost clip. All issues are sorted out.
Managed to drain the battery with cranking. Took it out for charging. This was the condition of the battery tray. Part is cheap, but not available as the model has been out of production for over a decade.
Hii,
It's been a long time, since the last post.
End of WFH era. Hardly getting any time.
