Stealth - 2002 Honda Dio
Thread Starter #16
deville_56
January 2022 - H4 Conversion
Water seeps inside the assembly during rains, resulting in a blown bulb. Yet to find the leak point despite multiple leak tests.
H4 bulb fits without much drama. Old BA20D bulb didn't have/need a retaining clip, so need some jugaad to fit the H4.
Bought Osram Cool Blue Mega HS1 35/35 - ₹ 220.00
Agni Ceramic Holder - ₹ 98.00
Old headlight removed from FZ.
Had retainer clip and rubber dust cap.
Installed them and were perfect fit on Dio's headlight assembly.
Dust cover also made for each other. Cut out the old connector and mated with the H4 holder.
Plug-n-play harness.
Cloth tape.
One of the clips holding the light was missing.
The clip.
Bought two of them right away, ₹ 5.00 each.
Cleaned up all the debris and wiped cleaned the reflector of any dirt. Lot of spotting and fading, might replace the assembly if available.
Beam adjustment bolt under the headlight. Loosening it allows forward/backward movement of the assembly.
Highest position.
Lowest position.
Corrected position.
Installed.
4300k temperature. Output is similar to old halogen bulb. Might upgrade to LEDs sometime in the future.
Thread Starter #17
deville_56
January-February 2022 - Updates
Where it was parked for years.
Found the Denso pair in my horn bin, removed from the Skids.
Fiddled with the screw and back to life.
Last horn relay from my bin, ran out.
Quick DIY fuse holder. First time on a micro fuse.
Plug and play horn wiring kit.
Installed Windtones in a couple of Dios in their golden era, which was claimed to be impossible by all installers those days. There was just millimetre clearance from the body with precise bending of the clamp. These horns were smaller and flatter, so finding space wasn't hard. Would switch to Yamaha Fazer pair soon depending on availability.
Done.
Shield mounting came off, so took it off.
Made one more spare key. Lost the previous duplicate and spare. Just ₹80.
Thread Starter #18
deville_56
March 2022 - Oil Change
Motul Scooter LE 10W30 - MRP ₹ 345.00, got for ₹ 280.00 from Ex-Jawan
17 mm socket for drain plug and strainer.
The strainer sits on the LHS. Drain plug almost exactly opposite in RHS.
Strainer and parts.
Around 550 ml drained. Exact a year and 2.5k km.
A little extra to compensate the oil that's stuck in the bottle.
Convenient long neck.
Thread Starter #22
deville_56
August 2022 - Updates
Generation gap, Honda Leads.
Used by my BIL and shocked to see it clocking 2.5k km in 5 months, otherwise doing yearly oil changes with extremely low odo clicks.
Repeat!! Motul Scooter LE 10W30
MRP ₹ 365.00, got a discount of ₹ 75.00, from Ex-Jawan.
Drained and filled.
They deleted the long neck with new stock. It was very convenient with scooters.
Gear oil change. Don't know when was the last change.
Both 12 mm bolts.
Bottom one is the drain bolt, common sense.
Shut off the drain and fill through the top.
Needs 120 ml. Filled some unknown brand using Yamalube bottle and a small piece of clear tube. Filled to brim and installed back the bolt. Done.
Thread Starter #23
deville_56
September 2022 - Prep for Retest and Misc Updates
Washed the Dio at a car wash. Bought secondary air filter and exhaust gasket, ₹ 40.00 and ₹ 25.00 respectively.
Engine compartment was dirty. Not cleaned in a long time.
Oil vapour all over engine head.
Cleaned up with TB cleaner.
Breeze
Location of secondary air filter
Just a screw in the bottom.
Bit dirty, but not damaged.
The cover.
New vs old.
Soaked with oil.
Installed, didn't resolve the issue. Symptom would be cold start issue.
The suction line to the SA was cracked. Cut the cracked section and reinstalled. Sorted out.
Exhaust was the only rusty part that needed fixing for the test.
Nuts were in tricky position.
Nuts covered in muck of ages.
Shield removed.
Just one more bolt and the exhaust came off after some shaking.
Painted using Nippon Pylac heat resistant black
Air filter box. Clueless as to how the muddy water got sucked in.
Condition of old filter. No idea when it was last changed.
New air filter - 17211KPL841 - ₹ 231.00
Updated Dio of the same generation came with viscous filter.
New vs old. New one by Minda and old one Lumax.
Replaced externally visible screws
and bolts.
Condition of the plug.
Cleaned the engine bay.
Bulb exploded again after wash.
Replaced with a 35/35W bulb lying around.
Removed the tint.
All reset and ready to go for the exam.
Thread Starter #24
deville_56
October 2022 - Completed 20 Years
Did the fitness test. Went with an agent, but after testing 3 vehicles in a row this year, understood that's a useless expenditure, and we can do it on our own without any fuss. Prep the vehicle, pay the fees, pick a date and present for inspection, simple.
Renewal of registration - ₹ 1000
Postal Fees - ₹ 45
Service/User Charge - ₹ 60
Total - ₹ 1105
New number plates were installed for the process. Bought from Sagar again. This time ordered with holes as the clamps were of standard size. Paid ₹ 300.00 for a pair including shipping.
Thread Starter #25
deville_56
December 2022 - Insurance Renewed
Renewed with Acko. Got comprehensive coverage with IDV of ₹16,770.
Third-party premium - ₹714.00
Own-damage premium - ₹86
NCB (50%) - ₹43
Net Premium inclusive of GST - ₹ 894.00
Thread Starter #26
deville_56
February 2023 - Oil Change
Motul Scooter LE 10W30 - ₹ 350.00 (MRP ₹ 381.00)
More than 850 ml in 800 ml bottle [lol]
Draining.
Quick funnel. Misplaced the right one.
₹30 discount coupon. Getting it out is a task.
600 ml drained at 2.5k km.
Low-low-low Merc.
Thread Starter #27
deville_56
March 2023 - Updates
Front brake started fading and speedo needle was shaky as the speed picks up. Speedometer cable and brake shoe needed replacement.
The spare guy gave Camp Auto brake shoes claiming they are better than Honda OE.
Camp Auto CA14B-401NA - ₹ 290.00
Speedometer cable was Vedant brand, which I was not confident about. Always trusted Suprajit.
Vedant VDC-4070 - ₹ 110.00
Work commenced.
Existing cable was running on single strand.
While removing the front wheel, there was some notable play and on inspection, the green bush was non-existent, fully disintegrated,
Got Gabriel bush kit.
Gabriel AM-20130021-1 - ₹ 80.00 (MRP ₹ 83.50)
Bushes and sleeves.
Removed pivot arm and cleaned the shocker.
Pivot arm was solid and had greasing nipple.
The right side wasn't as bad as the left.
Installation. Bush-sleeve-bush.
Installed.
Old brake shoe removed and plate cleaned.
So did the drum.
Magsol magic.
Removed the cam and greased
and installed back.
Brake shoe set and greased the pinion.
Work in progress.
Happy ending without any clicks.
Like he claimed, the brake shoes were great, bite was immediately felt, but created more dust and needed cleaning frequently and the sound was unbearable.
Thread Starter #28
deville_56
2023 June - Oil Change - A Social Experiment
I was curious about the "free" oil change at the Indian Oil pump for some time. Thought of giving it a try, partly because I was away from home with no tools and oil change was overdue and most lube shops closes by the time I shut my shop. Visited 2-3 IOC outlets including their COCO pump, all their VAS operated a 9-6 shift. Finally, landed at Simi Fuels. I was in the queue and got my chance around 8 p.m.
Lifted up for the job.
A man in his 50s was doing the change. He picked up the right stuff. Paid MRP, conveniently swiped card.
Servo Scootomatic 4ST 10W30 - ₹ 330.00
Drained the oil as usual.
Then, there was this suction machine. Sucked the remaining oil through dipstick hole.
This is the guy. Poured till almost the last drop. He was very patient and gentle on the scooter, especially with the drain bolt.
Icing on the cake, got ₹ 50 voucher, effectively making it ₹ 280.00 for the oil with free labour. Filled it right away.
There remained a queue the time I left. Definitely worth the try.
Thread Starter #29
deville_56
June 2023 - Starting Trouble (Again)
Tube connecting inlet pipe to air suction valve cracked again. Cold start and idling will be problematic. Needs choke to start and extra throttle input to prevent stalling.
Got an Activa fuel hose. Not OE.
1768-KPL-8400 - ₹ 80.00
Cut and paste. Don't think it's gonna last long from it's appearance.
Check and cleaned filters and plug.
Got a deep 10-mm socket for deeper jobs.
All sorted out.
Thread Starter #30
deville_56
August 2023 - Updates
Different gen, same colour.
Camp Auto brake shoes creating too much dust and wear, but bite is still great. This is the reason I'm not suggesting them despite their performance.
New key chain. Superman. Found it at a supermarket at discount price - ₹ 99.00
Scooter was dirty all under the skin. Engine hanger bush was almost done with.
Stripped and washed.
Changed oil. Back to Motul.
Motul Scooter LE 10W40 - ₹ 360.00 (MRP ₹ 386.00)
Screw tabs were all broken, thanks to my careless BIL.
Clean engine bay.
All set.
Gave it to a newly found FNG (who helped me with a stranded Karizma) to replace the engine hanger bush, who knew all the tricks in the trade, who tricked me taking a sum for inspection, saying no issue with the bush, which I knew was wrong.
