Some New Gadgets Found
Thread Starter #47
Ceramic Chick Egg White Separator — The clean and easy way to separate eggs
Mirror Clearer — The ingenious bathroom mirror wiper! Simply attach the suction cup to the mirror and clear your bathroom mirror of steam with one easy stroke.
Compact design that mounts your tablet up high and close to the headrest.Converts an iPad into a backseat theater.
Cleverly designed tool. Simply insert the shaft into the top of a trimmed pineapple, apply light pressure and twist the handle. Lift the flesh from the peel, then slide the dicer down the stack of rings.
Source FB [WellDoneStuff.Com]
Thread Starter #51
Easy to unplug. I think this is very useful as well as very safe. Hope our electrical companies like anchor and others have a look at it and make some thing similar to this..[clap]
Thread Starter #56
Crowning glories can be achieved with perseverance, skill and smearing your mouth with toothpaste. Get triumphant teeth with today’s Groupon for Automatic Toothpaste Dispenser!
Smeared with sauces, stained with rich chocolate and little pieces of broccoli stuck in tiny gaps - most days are tough for your tiny chompers! Keep your pearlies white and bright by brushing them twice. To add to the experience - use the automatic toothpaste dispenser we have up for grabs. It can even hold your toothbrushes!
Prevents wastage of toothpaste because fixed amount of toothpaste is dispensed
Easy to install using 3M double-sided adhesive
No electricity or batteries required
Made with food-grade material
Easy to take apart and clean
Size: 150 x 60 x 64mm
Touch Me Auto Toothpaste Dispenser Toothbrush Holder White - YouTube
Thats the issue with few cool gadgets. Most of them are either costly or may not be easy to purcahse in local cities either. Should be present in local market will be amore nice thing
