Review: LED Headlight Conversion Bulbs For Cars & Bikes
I just fitted an excellent HID set for the low beams on my Pajero Sport.
Bought from tdautoz on ebay.in.
The model nbr is UG-AS-42-T4
They're H11, 42 watts, 4500k
Fitted them as replacements for the Philips HID set - 50,000 km, just over 4 years.
Remarkable improvement! Beam's almost twice as bright and covers close to twice the distance.
It's slightly yellow, which I find more restful than white.
Kolhapur
I sent the seller a message on aliexpress asking him about the exact dimensions so I can know if it will fit.
bhvm, did you have any heating problems with the i10 considering that while the dust cover is placed, there would be no exhaust of hot air from the fan.
AHC, so you tried but the bulb didn't fit in the verna? or did you buy it for the figo in the first place?
Thread Starter #168
After 5~6 Hours of Night driving there was no overheating, No Lumen decay.
Thankfully, i10 caps have a bit of bulge that allows fan to work properly. Interestingly, the headlamp housing is still sealed from the environment. I guess the amount of air circulating inside housings is in itself enough to cool these little kiddie 30w of a light.
Lucknow
Thank you for your valuable feedback and support.
The Kits installed are the latest upgraded model of our HID kits which uses ASIC chips. This is the best technology so far we are aware of. Also, the bulbs which we use now claims to produce 50% extra brightness, covers +50 m extra distance.
Hope these kits will last for ages and there should be no decay over bulbs even after two years. [drive]
I bought them for the verna. When I went to the installer he said it won't fit so didn't get it installed.
Dibrugarh
Please upload some pics
Kolhapur
The bulb did not fit or there was no space for driver?
So, after waiting for days for the seller to reply, he said that the bulb may not fit and told me to look at some sort of G5 or V16 headlight [confused]
I guess I will try my luck and buy the regular cree bulb (2nd link bhvm posted) as it seems to have the smallest dimensions. And does not have fan (uses aluminum heatsink instead)
Thread Starter #174
So, the seller replied and said that this bulb should be OK. Idk the logic behind why this should work while the earlier one won't. Thoughts, bhvm?
Seems like a stupid side firing bulb. LEDs are in wrong position.
Clearing Unsold or outdated stock, perhaps?
Kolhapur
LEDs these days come with small coloured stickers that allows you to tune the color.
Regular Cree option-
https://www.aliexpress.com/item/2x-...Hi-Lo-Beam-Car-DRL-Fog-Light/32681657142.html
Ordered the above bulb. Let's hope that it fits. I did a few measurements today while replacing the bad Xtreme vision with the stock bulb and it should probably fit but it will be a tight fit.
Does anyone know where the H4 socket for this bulb is 'cause I don't see it in any of the pics.
Lucknow
Hi Silverjet,
If i am not wrong you wanted to know the H4 socket of the attached bulb. Please find the attached pic of h4 socket marked with an arrow.
Hope this helps.
Tdautoz
Kolhapur
Thanks for the reply but im trying to know where the h4 plug is inserted on the bulb. Does it have a wire with female connector or is the plug at the bottom of the bulb? Maybe im being dumb here but i just can't get that from the pictures.
Lucknow
oh ok.. sorry my mistake rather.[:)] Yes in the picture they have not shown the wiring however i am 99% sure that it will have wire with three pin connector for direct plug and play.
kkn13
Any easy fitments for Innova(the model just before Crysta) and 2011 City?
My dad got some white lights installed in the empty foglamp space(not sure which brand etc, not an expert on this)
He does alot of highway driving and wants a headlight upgrade to "white lights" :D
Criteria- OEM look and feel, minimal work etc
City upgrade isnt necessary but I want to know about it so that I can think about getting it done :D
My concerns are reliability,shouldnt blind anyone, should feel OEM like the Germans and even Baleno,Ignis,Tucson etc which get them
NH
Hi Guys! Its been long time! Just wanted to upgrade my '15 city headlamps for better vision at night. I'm in love with the LEDs and drool whenever i saw one pass by me. Can i get the same output from leds without using the HIDs? There are lots of products in Aliexpress for HB3 and H11 specification. It would really help if you guide me to the right one. I prefer white as it looks cool and complement my DRL pretty much. FYi im running 55w/60w currently without any relay dont know the brand but not the stock bulb. Can check if needed. I donot have fog lamps and interested in getting white one too.
