Re: My Buying Experience of Manza Aura Quadrajet
For manza 1st oil change is at 20000kms, that oil change make the difference as residue from 1st 1000 kms is more (due to engine run in period) which affects the engine efficiency hence after 1st oil change you will see the FE improved by 3-4kms (depends upon your driving style)
No problems at all, this is what engine run in makes the difference, when engine is new, oil has less residue as engine parts rub it leaves the oil with particles which pollute the oil & affects the mileage & rpm, hence now you need higher RPM to attain the same speed.
Once the full rubbing of engine parts take place within 5000kms it wont rub the same amount in future. After 1st oil change you get more mileage & hopefully the rpm/speed will better match.
during initial period like upto 1 year of car ownership, the FE will be lesser and later will improve. What is the reason for this.
Is this any problem or this is some calibration error.
