re: My Modified Maruti 800.
- Child Lock. Is this possible for 800?
- Fog Lights - What will be the approximate cost for fog lights and any performance issues with this
- Interiors, fabric inserts, cushy arm rests,
- Brake Boosters - Need Varun's help here
- Alloy wheels Is this only aesthetics or is there some functional aspect to these?
Child lock - Haven't heard of anyone doing it reliably.
Fog lights - depends on how much you are willing to spend. Hella MicroDE that I have in my 800 cost 5.4k. You can get MicroFF for a similar price. Advantage - they can be fitted on the bumper, without much additional fittings. Performance issues, just that your battery will be drained much faster with the additional load. If it's just the occassional night trip, this isn't a worry. Other than that, nothing that you'll ever notice.
Interiors - you can visit some upholstery shop and find out. JC road in B'lore would be a good place, I guess. I'd done my seats for around 4k last year in Palakkad. Nothing other than seats.
Brake boosters - You'll get KBX brake boosters for 3.5k. Best place, GP Road, Chennai. Any MASS can fix it for you.
Alloy wheels - my advice is to go for good, branded ones, and not Taiwan/Chinese/Thai local makes. The branded ones would cost you 1-2k extra, but they give you warranty. The others won't. And it's a risk too - these cheap ones might not be tested and qualified, plus, their offset and weight might not go well with the suspension components. Busted suspension parts will cost you a bomb, and also pose a risk to your safety.
You get Plati alloys for 11-12k (set of 4) in JC Road. Neowheels for 12k, Bridgestone Tiara for 13k or thereabouts.
The advantage of alloy wheels are:
1. improves ventilation of the disc/drum and the wheels - tyres would run cooler
2. slight reduction in weight -this comes only with branded ones. Cheap ones sometimes weigh more. Less unsprung mass = less inertia to movement = slightly better FE
3. Aesthetics.
Disadvantages:
1. Breakage - can't take abuse as much as steel rims, and they break instead of bending in similar conditions
2. Bents - you can't repair a bent alloy, you have to replace it
3. Cost
