My Maruti Suzuki Alto LXi
Hi ,
There are no options in alternator in alto as I was planning to swap my alternator..
I have the diagram, lets check the ECU..
Please confirm the model, euro 2/3..
lxi.
car is looking nice.
Wow! Looks nice. Just get new type ORVMs of K10 from some aftermarket shop.
The car looks incomplete without that. I am also going to get them.
Thread Starter #113
Kollam
Roots Windtone in Alto LXi
Some clicks:
1.Terminal clip with sleeve (Heat shrunk sleeve) and 2.5MM Wire from battery to Bosch Relay.
2.Fuse Box(Blade Fuse Box) from Ape ,45rs,currently having 30A Fuse,Forgot to replace it with 15A,Bought two 15A Fuses,5rs per Fuse,Fuse is made by ROOTS.
3.Horn with custom made clamps and relay placed on the side.:) All clips and ends were secured with Sleeves,Sleeves costed me 8rs per meter,Available in different sizes.
Re: Roots Windtone in Alto LXi
Some clicks:
Will be posting mine soon. Gonna celebrate my 25th horn install also [evil]
Thread Starter #116
Kollam
Alto lxi Horn Installation
Hi, Very neat installation..
Thanks,This was my first Horn Install.
you could have retained the stock horn and use a switch between these two..
In my Karizma,I used to have both horns(Stock and Windtone ) with a 2-Way switch,But didn't used the stock ones after fixing the Windtones,So never thought of it again.[:D]
Wow..Congos bro.
Alto Horn Installation Expense:
Roots Windtones-540RS
Bosch Relay-170RS
2.5MM Electrical wire(5 Meters)-90RS
Horn Clips-10 Clips,1 RS per clip.
Fuse Box(Ape) 45RS (Comes with a 30A Fuse)
Fuse (15A) 5RS per Fuse
Sleeve-1 Meter(8RS per meter)
Zip Ties-75rs(100 nos pack)
Labour: DIY [:D]
Total: 935RS
lxi.
Mine costed me-
Horn (It was not ROOTS) - Rs.550
Relay - Rs.50
Labour - Rs. 0 (The shopkeeper was a known guy!)
Total - Rs.600!
They are going strong now!
The sound is same PAW-PAW type (Skoda)!
Thread Starter #118
Kollam
Latest Pic.:)
Went to an alloy dealer for checking alloys for my friend,also saw one for alto.:) 12.5k for a set of 4.:)
