^^ Nice click buddy, you maintain the car very well! The white color is really a gem.
I'm missing my alto very much, its only been two days after i parted with my love(alto) but it feels like 2 years.
Hi Aneesh, i see your ride is sooo cool and kept clean very much.how do you treat the engine bay? specially the electric wiring and equipment. its important to keep the engine clean so it cools down faster so increase in the performance.
i guess its time for a alloy upgrade too.
if you get a fog lamp wire it outside the ignition key so you done have to use the headlight lamps switch every time to switch on the fog lamps. i have wire them separately so i can switch them on/off any time i want as its has a direct line to battery.
i can switch on/off it on daytime and rain too but no need to switch on the parking.
yes it good but want remove the dust.. use some good (like 3M ,Wurth) de-greaser and clean it off once in a while. it will remove the dust,tar,grease,oil so it want get deposited as black grits in the engine equipment.
IMO its good to clean every 30K - 40K. it increase the fuel consumption and remove the sludge's from engine and i have notice the engine sound gets better.
may be two reasons water gone in the petrol tank or fuel filter ,change the fuel filter and try to remove the water from tank.
else need the injector and the air intake clean and replace the air filter.
they will remove the jerking.
yeah my tech tole me it could be a problem if the fuel filer was clogged or if water was in petrol. i had same problem and in the beginning and after running some 2000Km it was fine but i did avoid some fuel pumps as i suspect them they are full of water.
