What is Vehicle Stability Control (VSC), experienced yesterday.
I was on a roundabout, and speed between 80-100km/hr. I noticed that irrigation water is overflowing, and inner roundabout circle is partially filled. I entered into roundabout, and took a sharp curve with the above speed. Then all of a sudden some siren and something happened. I realized later that it is VSC kicked off. Thanks VSC for soft landing.
VSC helps prevent wheels from slipping sideways when cornering or sudden steering. VSC is a system that helps prevent side skids and help stabilize the vehicle while turning on a curve. When the vehicle senses a loss of traction or a slip, braking is automatically applied to all 4 individual wheels and engine power is reduced to help secure the safety of the vehicle. For example, if the steering wheel refuses to turn from over-speeding (under-steering), the vehicle will take control to steer toward the inner curve. Also, when the vehicle begins to spin from abrupt steering handling (over-steering), the vehicle will take control to steer toward the outer curve.
The above exactly happened. Some photos taken while on morning time. It is some vehicle caught fire.
