Looking at the engine from the top we see the cylinder head is the tappet cover/cylinder head cover.Modern engines have a plastic cover over this part.
The cylinder head is the one which contains the valves and rockers and it sits on top of the half engine.
The half engine from Maruti does include the crankcase,crankshaft,pistons and conrods.
The pistons move in the cylinder bore.This forms the lower half of the combustion chamber.The top part being the cylinder head which houses the spark plugs and the exhaust and inlet valves.
The lower part of the block is known as the crankcase since it houses the crankshaft.I think you are mistaking the oil pump that sits in front of the crank case as the oil sump.The oil pump sits right behind the crankshaft timing gear.
The only things you do not get with the half engine block is the the cylinder head(including the valves and rockers and tappets),water pump, oil pump, timing gears and the oil sump.
Please go to an MGP store and ask about it.
Alex, we are not attacking you in anyway.I just think you are confused about what is what.
I never missed the head, and i never mentioned the oil pump in the post,
And nobody is attacking me bro!!!
From the above one you had copy/pasted says that,crankcase comes at the lower end of the cylinder block/half engine, which houses the crank shaft.( that is the oil sump or the oil pan,in a fiat or a maruti engine.)
That is the crankcase.
Nothing other than oil strainer comes below between the oil sump/oil pan and the cylinder block.
The oil sump/oil pan/crankcase all are same in the fiat/maruti engines,
I need not need to visit a MGP store to clarify this, and the guys at such stores are just salesmen who take orders/delivers by part number by looking at the manual provided by maruti.
Guys, the engine from the top, its the valve door cover,then the head, then the cylinder block(the half-engine)then the crankcase(oilsump,oilpan) in between the sump and the cylinder block comes the oil strainer.
The one that is marked crankcase in the pic is actually the cylinder block or the half-engine.
I do agree that in merc and other premium engines there is a 'case' which comes between the small oil pan and the cylinder block which is as bigger as the cylinder block and this 'case' is called the crankcase on such engines.
But as we are discussing the fiat engine in the ertiga. the crankcase.oilsump and the oil pan all are the same.
Guys as we search on the web we may get two answers because in merc and all, there is a 'case' in between the smaller sump and the cylinder block which is called the 'crankcase', and in other engines which we are used to have only one thing below the cylinder block and that is the 'crankcase' or 'oil sump' or the 'oil pan'
@sam,
Bro i was asking the owner to check the under body for further scratches.
And the conclusion you jumped was on the crankcase, which is confused on net as the merc and premium engines have a case other than oil sump which is called a crankcase on such engines,
and at the engines discussed the crankcase and the oil sump are the same.
@All.
and in other engines which we are used to, have only one thing below the cylinder block and that is the 'crankcase' or 'oil sump' or the 'oil pan
