Well, to be honest the first thing i looked at is the brand FORD. Since my younger days i always dreamt of owning a FORD car, which however didnt happen till now due to budgetory problems. Then offcourse for its best value for money pricing.
Apart from the above i liked the spacious interiors (compared to other hatch backs), easy maneuverability, coolest A/C and offcourse for its comfort.
However during my test drive it didnt took off well in 2nd gear i.e whenver i changed gear from 1st to 2nd the engine was almost coming to halt with some vibrations (changed the gear after around 1500rpm) and in slopes of our bangalore, it was almost impossible for me to go in 2nd gear and i was forced to downshift midway. When i asked sales executive about this, he informed me that it takes off well ONLY after 2000rpm
in 2nd gear (i.e when turbo takes over i feel, pls correct me if i m wrong) and i tried that, and offcourse he was right. so overall i was satisfied and booked the car without second thought as it was from my brand FORD.
![Surprise [surprise] [surprise]](https://www.theautomotiveindia.com/forums/images/smilies/Surprise.gif)
Yes, as many would feel, 2nd Gear could be a dead gear, if not fed properly. If you are on right RPM with enough torque, then you would never feel the lag. Moreover, remember that Figo is the heaviest AC in the lot, which means, a lot of power drawn from the engine. So, 2nd Gear + AC + Fully Loaded, is not fun to try. But, if you manage the 1st gear well and upshift to 2nd at right RPM, then no problem at all.
BTW, you mentioned, you tried taking off from 2nd and the engine died. Yes, it will and mostly all diesel engines would, unless pretty consciously and tactically done.
But when i saw this thread along with your other thread regarding FE, doubts started to peek into my mind as i had also faced problems in the 2nd gear only which is the talking point in most of the threads of figo.
If FE is your only concern or rather requirement, then you should go for any MS cars.
