Hi buddy, thanks a lot for the tips.
In fact, I found Sub Woofers, JBL 12" SUBWOOFER WITH ENCLOSURE CS-1215B
and
4 channel, JBL 4 CHANNEL AMPLIFIER GTX-646
which can be delivered in my area by the seller from Chennai.
I called up the seller and he says the "
JBL 1215B -12-SUBWOOFER-WITH-ENCLOSURE" will not fit in Innova's boot. Really want to find out the truth.
Will you be able to give me the measurements of this box?
You can even post some pics, that will be helpful. As you mentioned, it is flexible and I can hook it up to other speakers in the futue. All the current speakers are factory fitted(OEM).
From the net, I found that this box is 40 CM length, 35 CM width. Is this true?
Actually, Innova's boot is not that big, unless I fold a seat.
Do you think, an 8 inch active sub will suit a huge car such as Innova? I am in bit confusion![Surprise [surprise] [surprise]](https://www.theautomotiveindia.com/forums/images/smilies/Surprise.gif)
Looking forward,
Joshi Thomas
and
Looking forward,
Joshi Thomas
Hi Joshi, I have the same amplifier and Subwoofer combination in my car. It fits in my Honda brio which have almost non-existing boot space
. So AFAIK it will fit in easily (15cm depth only) without hindering the space for luggage in Innovas boot. But are you sure these models are not declared as obsolete by JBL?
If you are using a GTX 646 you can use it for front component speakers as well, any day it will give a much better output than your coaxial speakers (I assume you are having coaxials at present) and Active subwoofer combination. If you are using an active subwoofer only the subwoofer output will be amplified. So as long you are a normal user and not much of a bass fan and also you have made your mind to spend 13k, my humble suggestion is to stick with your earlier plan of JBL setup
