Hyundai i20 1.4 CRDi - Test Driven
Kannur,Kerala
I don know what rattling issue you guys are mentioning! My friend owning one for 3 months has not faced anything till that.
ratteling means a kind of "kdak" "kdak" sensation is felt in steering wheel while passing pothole or bumps. even though it is not much audible but feeling makes you think that something is getting disconnected from wheel or a loose joint.
i had same issue in my ford ranger but it appeared due to horrible abuse which a.s.s centre could not fix. they said it would require them to replace whole steering assy.
Hmmm i will notice this more carefully when i travel next in his car. I think he din face anything of this sort till now.
Just full throttle , perfect gearshifts and a clean stretch of a 6-lane NH road ahead! The 110BHP engine can pull it off under 10 seconds easily!
Margao, Goa
Re: Hyundai i20 1.4 CRDI -Test Driven
None of the Hyundai's are good handlers above 100kmph(don know about SUV'S though). The ride becomes very wobbly , bouncy , stability is not very inspiring!
I'm having the same problem with the i10. However this problem can be partially rectified with better tyres. Otherwise you can also go for an aftermarket suspension.
Yes that is what i am also hoping for. My Verna needs a tyre change soon and i am hoping that the stability and handling increases atleast a little!
Cochin
"Hyundai i20 1.4 Magna Diesel with ABS Rs.6,50,021*"
Is there such an option in i20
I am planning to but i20 crdi, was told ABS is only in i20 Crdi Asta
Vijay2011
Yes hyundai i20 crdi MAGNA does comes with ABS as an optional feature.
Cochin
Dear Amity
My Showroom guys and i20 brochure also tell there is no Magna option with ABS. Could you please confirm if it is available, so that i can opt for that.
IMO Sports Option have Alloy wheels not ABS.
Vijay
I will again check and will let you know. However I have seen and see that car everyday, which has abs sticker on it.
