I have been charged 23,646 for Insurance (default was Bharti Axa but I got it changed for ICICI Lombard for the same price). Is the price too high? I have no clue about Insurance prices.
Thread Starter #1,127
Vadodara
IN EXTENDED WARRANTY,I THINK ONLY ENGINE,CHASSIS AND SUSPENSION ARE COVERED AFTER ALL BELOW EXEMPTIONS.
AS PER HMIL THE EXTENDED WARRANTY DOES NOT APPLY TO:
"This warranty shall not apply to:
Normal maintenance services including without limitation, cleaning & polishing, injector cleaning, engine decarburizing, engine tuning, oil/fluid changes, filters replenishment, fastener retightening, adjustments of doors, brake and clutch, wheel balancing, wheel alignment, tyre rotation, head lamp alignment.
Replacement of parts as a result of normal wear and tear, such as spark plugs, belts, brake pads and brake shoes, brake discs, clutch disc/pressure plate, filters, wiper blades, bulbs, fuses, brushes, hoses, tyre / tube, battery, audio system, catalytic converter, silencer / exhaust pipe.
Tie Rod ends, Steering Ball Joints, Rear Shockers, Front Struts, Dicky lifters, Front & Rear Wheel Bearings/wheel hubs are not covered beyond 60,000 kms of operation
Rubber parts like Wheel Cylinder kit, all doors weather -strips/beadings & A/C "O" rings
Clutch cable, Accelerator cable, Speedometer cable & Tail Door Opener cable.
Leakage of A/C refrigerant.
Normal aging, deterioration or rusting of plated parts, paint coat, rubber parts, upholstery and soft trim, etc.
Body, paint, glass, interior or exterior trim, exhaust systems and normal wear and tear of any other component.
Damage or failure resulting from: Negligence in getting the vehicle serviced within the stipulated kilometers and time period as mentioned in Owner's Manual and Service Booklet.
Misuse, abuse (such as racing, over loading, riding over the clutch), accident or collision, theft, flooding or fire.
Use of improper, adulterated or insufficient fuel, fluids or lubricants.
Use of parts other than Hyundai Genuine Parts.
Any device and/or accessories not supplied or not approved by HMIL.
Modifications, alterations, tampering or improper repair.
Parts used in applications for which they were not designed or not approved by HMIL
Any repair carried out other than by Hyundai Authorized Dealer/ Service Centre.
Slight irregularities not recognized as affecting quality or function of the vehicle or parts, such as slight noise or vibrations, or items considered characteristic of the vehicle.
Airborne fallout, Industrial fallout, acid rain, hail and wind storms, or other Acts of God.
Paint scratches, dents or similar paint or body damage.
Revolution or Mutiny, any intentional or malafide act of owner or a driver, abuse of the vehicle, negligence.
Action of road elements (sand, gravel, dust or road debris) which results in stone chipping of paint / glass or damage to any other part.
The vehicle which has been used for any sort of competition, sport and rally, transport for hire of persons or goods, Taxi service or short or long term self drive hire or driving school or any commercial use.
Any vehicle purchased as a taxi under the special excise concessions or/and registered as a tourist taxi with the Transport Authorities.
The vehicle in which the odometer has been tampered with, changed or been disconnected.
Incidental or consequential damages, including without limitation, loss of time, inconvenience, loss of use of vehicle or commercial loss.
No liability will be accepted for any losses covered under an accidental damage or road risk policy or for any road hazard/fire or accident damage, no liability of any kind exists in respect of third party.
no liability will be accepted for damage caused by neglect, intrusion of foreign or harmful or injurious matter, lack of servicing, overheating, freezing or abuse to the continued use of the vehicle after a fault has become evident or for consequential loss on the failure of parts not covered by this Extended Warranty .
If model equipped with Hyundai Genuine LPG kit. following parts Rubber pad, Hose adaptor (Inlet & Out let ), Gasket, Tube, Band cable, Holder tube, Vaporizer to mixer hose(fuel, Vaporizer Cover hose (air), Strap, Water Hose Assembly( in & Out) , First diaphragm Assembly, relief diaphragm, first valve Assembly, 0-rings set will not be covered .
Vehicles fitted with non-genuine LPG/CNG kits are not applicable for Extended Warranty.
No dealer or its or his agent or employee is authorized to extend or enlarge this warranty and no dealer or its or his agent or employee is authorized to make any oral warranty on HMIL's behalf. HMIL reserves the right to make any change in design or make any improvement on the vehicle at any time without any obligation to make the same change on vehicles previously sold. Warranty service shall be provided only by HMIL's authorized dealers and Dealer Service Branch. HMIL's decision is final and binding on the Owner of the vehicle in all warranty matters. HMIL reserves the right for the final decision on all warranty matters."
[surprise]
What was last year insurance cost you had with your vehicle??[confused]
[cry] How much did you pay? And also which insurance do you have?
I don't exactly remembered the figure but it may costed about 18k. By the way I have also googled for insurance and extended warranty for grand i10 diesel, they are quoting 22331 and 8203 subsequently.
you can check the below link
Advaith Hyundai Web Showroom :: Grand-i10 :: Pricelist
Thread Starter #1,133
Vadodara
I had IFFCO TOKYO insurance through dealer and it cost me 20K.
(Its not zero-dep)
Hi ashurd10,
Mine is zero dep and it costed me 19K from Bajaj Allianz. Please check your IDV, it should be 5% less than your ex-showroom price.
Hi ashurd10,
(Its not zero-dep)
Hi GrandRk and Parth1231
Is your insurance bumper to bumper insurance? I asked my sales person and she told me that 2 times a year i can claim bumper to bumper and insurance will pay 100% for plastic components as well. normally they pay 50%- 55%. That's the reason for higher insurance price. Your views?
Hi GrandRk,
i will check the IDV and let you know. Did you take the insurance through the dealer? I knew it would be cheaper outside but I didn't wan to go for that.
ashurd10,
Insurance should be around 16-19K depending on your negotiating skill. Never buy insurance from dealer , they get fat margins on it. They will try to bluff , intimidate by saying dealer has tie-up , special consideration , fast settlement ...blah blah. By the way if they come to know you are not buying insurance from them they will become highly agitated and unresponsive.
When we bought the car extended warranty I think it was around 4-6k. As mentioned in earlier post "Extended warranty" applies only to engine and suspension. It is of not much benefit, chances of engine failing after 2 years is pretty less. As for as suspension is concerned they might use every dirty trick to void it. Best thing is try it as a bargaining chip, get free/discounted extended warranty [:D] (Newly launched car no discount/free accessories but something else...). It is something like insurance, only company benefits from it. If you plan to upgrade your car later after 2/3 years its avoidable expense.
Hi GrandRk,
Yes, mine is bumper to bumper and i have taken it from dealer. I have searched online myself as well and the difference was coming to Rs.500 - 600 so gone with dealer [glasses].
Please take time and once in a while go through entire terms & conditions of your insurance, dont rely on dealer or any sales person.
ashurd10,
Yeah. That's why I wanted to take insurance from the dealer itself. But still 23600 is too high I guess. How much did you pay and from which dealer?
Agreed. Warranty of only Engine and Suspension doesn't seem worth it. I am very bad at bargaining. I have already made the full payment. [frustration]. Should have checked it properly. Still it's the highly priced insurance which is bothering me more.
I paid 16.5k (zero dep)(21.5 dealer quote) from tata-aig. Bajaj quoted around 19k. You can take quote from policybazaar/respective insurance company portals. Dealing directly with them eliminates commission for middle-man hence lower rates. Normally insurance company provide a quote X and if customer does not take it then provide a discount of 15-25%. 23k is the max for that IDV so even if you get a discount of 20%-15% it will be around 18k. I never informed the dealer that I will be buying it myself. The dealer was so smart he only gave me the engine number and not full VIN while booking. After lot of protesting he allowed me have a look (no inspection/PDI!) at the vehicle and let me check the mileage. Then I took a snap(without his knowing) of VIN number which was pasted on the door glass. They do this as complete VIN is need to buy the insurance.
Then came the worst part , when I went to pay the full amount and informed him that insurance is not needed he started a big argument. "Sir you can do this" you need to buy insurance from us ...blah blah. Then he said insurance was already bought. Huh , how I asked him when he had informed us vehicle regn,insurance, release will only happen after full amount is paid. After some coercion and he accepted it. The dealer got his revenge by delaying vehicle delivery to sunday instead of friday ,gave me some randomly picked regn number and a plastic number plate. Further more I was forced to give in writing stating that I am buying insurance on my own and they are not responsible for it![shock].
Remember you are paying another 8-6K as handling charges which is nothing but another swindling charge.
Total ripoff = 5k (insurance) + 8k (handling charges) + 4k (extended warranty) + 1k (Accessories this includes mud flaps !, bargain it will be free) = 18k
If you go for loan, finance companies waive of first emi but most people are not aware of it. So part of it goes to dealer along with one month EMI as his commission. (Ever wondered why he is interested in getting you a loan ?)
Total rip off= 23k average, you cannot avoid it but can lessen it. If he pressurizes you , you can complain to hyundai. (This is one of the questions asked by hyundai CRM ppl on buying experience (yeah after getting ripped off)).
Sorry forgot the dealer. I bought it from blue hyundai Basvangudi, would surely avoid them. You have only four dealers and they are equally bad one or the other way. Two of them are known quantities (Advaith,Trident) and other two unknown (blue, lakshmi (never heard of them)).
Want more choices try Maruti !. I some times wonder why automobile companies crib about having low sales when they are represented by bad dealers and indulge in total ripoff.
