How Often Do You Check Tyre Pressures?
How often you check tyre pressure?
  • Total voters
    121
guys, on my alto its given in the placard to fill 30PSi and i always do the same. and my car is not on full load anytime. a max of 3 passengers at a time. that's all. so any problem if i continue on this?
No, it won't cause any problem. I drive alone for most time.
No Prob Sriharsha!
30PSi is normal & it will not cause any issues.
I think even 30psi is the recommended tyre pressure for alto [thumbsup]
Don’t worry if that’s what mentioned on the placard.
Bokaro/Bangalore
I am not sure about Alto, but for Punto they have mentioned 2 sets of pressure, one for midium load and one for full load.
Upto 300KG, medium load is sufficient.
Bokaro/Bangalore
For Emotion Variant (175/70 R14 84T)
Medium Load - 32 (Front) 30.5 (Rear)
Full Load - 33.4 (Front) 32 (Rear)
I normally keep 33/31.
Since Punto runs on R14 & R15!
My guess, it would be around 34 for normal load & 36 on Full Load.
Just my guess, lets see what RSM says :)
Bokaro/Bangalore
I read somewhere that air pressure in tubeless, in normal steel rims, gets reduced more frequently than alloys. However, i don't feel in my car. I check it mostly after re-fuelling and the pressure get reduced normally by 1-2 PSI.
Same here for the Fabia, different pressures are specified for the front and rear tyre for normal load and full load.
And I get my pressures checked every time I fill fuel, but also every time I hit the expressway, or go on a hill road / long distance trip.
Re: How often you check your car's tyre pressure??
Stupid question, but how to check tire pressure?
A decent tire shop or the gauge reading(when you fill air to the tire) at the regular petrol pump should do well,although there accuracy can be a bit off.Once every 15-18 days should be a decent interval for the no fuss motorist.
Tip-When you fill air to the tires if you notice one of the tires is 4 plus psi lesser than the other tires it indicates a slow puncture.For example 3 out of your 4 tires tires read 29psi but one reads 25psi it indicates that one has a slow puncture.
Thanks Prads, didn't know about this fact..
Cheers
Jazzy
I basically check them at the time of filling just before starting any long trip,else in case of short city trip,there is no question of checking it up.
