Maruti is giving out similar wrong informations at many places.
thanks AHI. regarding downhill drive, according to the manual of my alto, we need to engage the reverse gear and then let the car roll downhill and if we need to control the speed then brakes should be. used. i don't know how far is this true.
Even FIAT suggests, On slopes use the parking brake instead of the foot brake.
It doesn't looks to be correct.
Downhill
When driving down hill, try not to apply brakes, but use the engine brake (lower gear). Overuse of footbrake may result in total brake failure.
Vehicles going uphill should be given precedence.
Downhill
PARKING BRAKE - the name itself says it should be used when you park the vehicle.
This even causes distraction,one hand on steering & one on hand brake,instead keep it on the gear knob to downshift quickly if needed.
Nothing stops the car like the downshifting & braking combination does (Personal Experience) without loosing traction.
Moreover Parking brakes only lock the rear two wheels which may cause loss of traction in high speeds.
Overuse of foot brake may result in total failure - Dont worry,just a warning.Drive in lower gears,use the brake less.
