Hope all of us owning a car will know the pain of cleaning the interiors, especially the floor carpet. I hate that work! Yet, have no choice.
How do you do it?
Note, disregard the Vacuum Cleaner option. The intention is the make it easier for the ones who do not have access to it.
Here is my experience - Though I have a Vacuum Cleaner at home, I couldn't use it as I stay in apartment and can't pull out power cord from my home, neither would want to use the common electricity. Hence, I used to clean the floor with a cloth, accumulate all dust at a point and try to take them out. The last part is more painful than the entire process, yet not happy to get 100% satisfaction.
Of late, I tried using a brush, a hard one to clean the carpet and it's working well. Also, the stuff we use to pick garbage at home helps well to pick the dusts after accumulating it. Cons, the brush being harder, it make create bobbling in the surface and also the dusts is spread in to the entire cabin while sweeping it. So, I feel, a hand brush, maybe a little softer one that's available in auto accessories shop will do the job well.
How do you do it?
some cents from my side for your problem.
1. Even I live in apartment, but luckily on road side and that too in first floor. So I have managed to have a lengthy wire connected with plugs at both end (Male and female). Whenever I need to clean my car interior (mostly the floor) I use the wire and then connect my vacuum cleaner to it and happily clean my sparky.
2. If that is also not possible, why don't you try those small vacuum cleaner which can take power from your car itself. I think you can finish cleaning the floor in matter of 10 to 15 minutes if you do it in vacuum cleaner so it wont drain your battery also much (just a suggestion or idea, do not know much since not used this before)
Some pictures inn http://www.theautomotiveindia.com/f...-how-do-you-clean-your-car-14.html#post344281
Apart from the cons you have mentioned using brushes, I would like to add one more. I am sure your carpet's quality might go down if you use such brushes regularly.
