![Surprise [surprise] [surprise]](https://www.theautomotiveindia.com/forums/images/smilies/Surprise.gif)
Hi Bro,
1 final doubt: If i removing the full cover, do i have to worry about the bulb size?
I am planning to get the 24smd kit like u did on eBay , but im slightly concerned about the bulb casing size?
Since i have a brio, i am not very confident if the smd kit will fit properly. Also, will the lights come on as soon as u open the boot lid?
Nope, you don't have to. SMD panels will be having double sided adhesive, just stick it to the metal surface. You have three options to connect the power supply for it.
1. Don't remove the existing bulb casing, just plug the T10 adapter came with SMD panel and route its wire from the bulb casing to outside and connect the SMD panel. But I don't know if its gonna work on your brio.
No warranty issues.
2. Unplug the existing bulb casing, diy a plug/connector for the existing power plug and on side either use the adapter wires came with smd panel or use the smd panel wire.
Will have warranty issues.
3. Unplug the existing bulb casing, strip the existing power wires and tap either the adapter wire that came with smd panel or the smd panel wire.
SMDs, LEDs glow faster then halogen, incandescent, hid and etc gas/filament based bulbs but I'm telling about nano seconds.
If you wanna fit the panel inside the bulb casing and casing is same as our Honda City's; It has got 24 mm x 44 mm max area inside. So
this SMD panel is gonna fit. It has got 5630 x 18 SMDs which is brighter then 5050 that is present in 24 SMD panel so I believe it will be brighter if not same as 24 SMD panel. Unfortunately the same panel isn't available in India so you have to buy from HK. I have ordered the panel last month and might receive this month end.
BTW; you have hatchback so I don't think you need much light. You can buy a T10 SMD led bulb and plug it. Go for 5050, 5630 or 5730 SMD based bulbs since they are brighter and throw more light. Just measure the size inside the bulb causing and the buy the bulb which is gonna fit. i.e
5050 x 9 SMD India or
5630 x 9 SMD HK. You will get two so keep one as spare. :)
Thanks...
Best Regards
