Honda Amaze EMT iDTEC - Extraordinary!!
Re: Honda Amaze EMT iDTEC - Extraordinary !!!
Black and decker does a good job . Those who are in need of car vacuum cleaner , i tell you its power is more than enough and comes with 1 year warranty and the chord length is sufficient to cover bonnet and boot cleaning.
Pics of Mud flaps
Thanks for the vacuum cleaner pics. did you try it out on your amaze floor, how is the suction power? I see it uses a removable filter, do we need to replace it often? I am planning to get one, please advise
Thread Starter #35
Trichy
The suction power is good enough to suck the mud and hairs on the floor . I feel this as a correct tool .
Filter cleaning is a very easy process . Frequency to clean it I have no idea but everytime I used it , I remove the filter and clean it since its a simple process . Just press a button and turn the front portion . That's it .
I have done an extensive search and bought this . It really paid off . I can assure you b&d is a good product , comes with one year warranty and the list of service centres mentioned . So no worries regarding after sales . Go for it
Please send a query to the ebay seller about the size. If its for Amaze OEM should be 14" only.
ya sure . Its 2 kms from velachery railway station. proceed in the velachery railway station to meenambakam airport road. Once u cross sakthi cars, you call praba to pick u ...
The shop is a very small one. But dont get carried away by the size. The people out there do a splendid job in a professional way and they take a very good care of your car. Pricing is also very competitive when compared with other shops in chennai.Praba worked with Sundaram motors before 2 years after which he decided to start his own store. Since he was with sundaram motors, he knows very well about Honda's complex wiring structures inside and he does it in a way that will not affect our warranty . That is the reason I travelled 350 kms to him from Trichy. Praba 9940614769. and I am Thamil inian
I think I might also need his help. Since he had worked in Sundaram, he must be aware of Spark also.
I need to do rewiring of My audio system.
Thanks inian. As per your suggestion, I will plan well ahead and contact him. Since I am already in chennai, the planning should not be a problem.
Venky, have you met Mr. Prabha and what is your feed back?
Faridabad
Hi Guys
i Own a Diesel EMT Amaze and have driven 7500 kms.
Can i get to know how did anyone install the Mobile phone charging 12V port ?
i've a pioneer 2590BT head unit installed,
Hi Guys
I am also interested to know the same. I am thinking of buying EMT and I am worried on the lack of 12v port.
deville_56
You can get from any accessory shop. Commonly available ones 80-120 bucks. Xenos one with glowing outer ring, will cost 350-500. You can tap connection from HU connector (anyway you have to get HU connector for connecting HU)
Thanks for the information. will this void any warranty from Honda?
