@Dr MUDHAN
Being a ANHC owner, I find very useful data here. Thanks for taking your time to guide us all. I have ANHC VMT 2009 which came with Amaron OE battery with Status Indicator (3rd Picture) and have not replaced yet nor it gave any problems till date.
I would like to check the water level and add distilled water if necessary, however these Amaron batteries look different then standard, semi tubular or tubular batteries. I mean the 2v x 6 distilled water cells. I guess they are inside two square caps left and right (DANGER/CAUTION, RECYCLE & etc warnings written above) but don't wanna take risk opening them.
It would be good if you provide detailed info on how to check the water level and add distilled water.
Also let me know, whether do we need to unplug battery terminals before checking and adding distilled water?
Thanks...
Best Regards
Thanks...
Best Regards
HOW TO CHECK & ADD DISTILLED WATER?
You are right!
We have to pry open those two lids to reveal the filler caps.
However, it is a Maintenance free battery; there is no need to top up with distilled water for a very long period of time unless we notice some problems. Evaporation could occur mostly due to hot environment or over charging.
Longer cranking time / few more attempts to start the engine are obvious signs that the car battery is weak. The indicator ‘charging eye ’ will go from green to grey. The volt would be 13+ instead of 14+
Most of the car battery today is not 100% Maintenance battery. They are ultra-low maintenance batteries and there is a provision to add distilled water if need be.
TO CHECK & ADD DISTILLED WATER:
Please do it in a well-ventilated area.
Wear goggles & gloves for better safety.
Clean the area around the battery terminals and the top of the battery of dirt, debris.
Open the lid / the 6 seal caps if there are by unscrewing it or using an appropriate screw driver.
Try focusing a powerful flashlight on the inner side, and see if there is any drop in the water level.
Add carefully with a syringe (Get a 20 ml disposable syringe from medical store)
Fill to the maximum safe level—avoid over filling or flowing and make sure the cell plates are covered. Some batteries have Min / Max level lines.
Always do in the morning before you start the car and better run the car for appropriate charging.
No need to unplug battery terminals as we are not going to touch the terminals by metallic object.
If required, always disconnect ground Cable first and connect it last to prevent dangerous sparks.
Honda after sale service schedule will take care of this too. You can also tell the service people to take care.
