PART II
HOME MADE BATTERY CHARGER & THE SUCCESS STORY … Continues
USING LAPTOP ADOPTER WITH STEP DOWN / STEP UP POWER CONVERTER
ALSO THIS VIDEO @ YOUTUBE DIRECTLY:
You need Step down (or) Step up Power Supply Module. You can also try as in this video but you need to do carefully, ignore the language if you do not know, but note the procedures.
The procedure is same as I did, only thing the extra Power Supply Converter Module helps to output the ideal Voltage/Ampere safely for charging the battery, as depends upon the Laptop Adopter, whether 12Volt or More.. By Stepping Up /Stepping Down.
Kindly note, buy a module where you can control both the voltage and amp output depends upon the requirement. In some modules, you can only control the voltage and the amp is 2 constant.
Check availability in amazon.in:
1.
DHRUV-PRO 5A DC to DC CC CV Lithium Battery Step down Charging Board Led Power Converter Lithium Charger Step Down Module XL4015 RED
2.
CentIoT - LM2596 LM2596S DC-DC Adjustable Buck Step Down Power Supply Module
3.
core technologies XL6009 DC-DC Step-up Module with Adjustable Booster Power Supply Module
USING A TWO-WHEELER TO CHARGE THE CAR BATTERY.
See the video, ignore the language if you do not understand, but note the procedures.
First, remove the car battery and keep on the two-wheeler at a convenient place.
Just access the two-wheeler battery, remove its terminal clamps. Leave the two-wheeler battery untouched. Connect the two-wheeler battery clamps positive-to-positive and negative to negative of car battery through normal wires. Kick start the two-wheeler. Run the two-wheeler 20 to 30 minutes; monitor the direct voltage, stop once reached around 12. Now, refit the cat battery, start and run the car. Done.
Good method as in this video, safe and easy but you need to tax the two-wheeler engine.
USING HOME PC UPS BATTERY
- WITH UPS BATTERY IN GOOD CONDITION
It would be helpful when you have two 12V/7.5A Batteries UPS that is 1KVA Type.
You need to remove the batteries from UPS.
Remove the fully charged two 12 volt batteries (
CONNECTED IN PARALLEL to have the same 12 volt but 15 amps i.e., 7.5x2 ) connect to start the car. For smaller vehicles fully charged one battery can do.
OR
- WITH OLD UNUSED UPS WITH NO BATTERIES
Open the UPS, get the positive and negative terminal wires that used to charge when batteries inside. Connect external wires to each ensuring carefully the positive and negative lines. Take out the wires to car battery terminals after disconnecting the battery from car lines. Switch on the UPS, Check battery charging with voltmeter, once it reached 12V (mostly within 30 minutes), switch off UPS, disconnect everything, and connect the battery to car. It’s done.
USING A JUMP STARTER & JUMPER CABLES:
JUMP STARTER - Expensive, not useful to Individual Owner. It’s nothing but a SUPER POWER BANK, need to be kept in charged state property. May be useful to Mechanics, Multiple car /Fleet owners.
JUMPER CABLES - If you own multiple cars, or have a helping friend with a car, jumper cables would be useful. OR Always keep two different colored thick wires in the car if it has an old battery or if you failed to switch of any lights at parking as it would be very useful when you out stay and if the car failed to start. It’s just positive to positive and negative to negative connection.
BUYING AN EXTERNAL CHARGER
Good ones are expensive, its threshold limitations to be noted. Example, if the necessary requirement of 8V threshold means that depleted battery's charge should not be below 8V because then it will wrongly recognize the battery as 6V battery despite a 12V battery.
BATTERY SALES SHOP
Risk free
, if you have nearby a good, professional dealer’s battery shop opened and can wait a day or more. Moreover they can also set right the battery chemistry like acid top up, right specific gravity if needed and restorable.
OTHER METHODS:
Some successfully revived the weakened two-wheeler batteries by using 12V/2A Adopters that comes with some Set of Box, Router etc.
FINALLY,
Don’t let the battery down as far as possible and I found out the reason for my case; I should have not used Portable Tyre Inflator,
![Cry [cry] [cry]](https://www.theautomotiveindia.com/forums/images/smilies/Cry.gif)
that consumes lot of voltage (the car voltmeter readings comes down to 11.7 from 14.4 while engine is idling) especially when the car is unused for quite some time.
Thank you for reading this thread.
