Boss,
Restoring an used bike is a pleasure. Btw, how much did they charge for Sand blasting the frame? And where did you manage to get the parts in Chennai.
Boss,
Not sure about the cost for sand blasting, it is inclusive of the painting charge.
And for the parts, most of the genuine parts are available with "Chennai Two Wheelers"- Tambaram and Two Wheeler India - GP Road
Experts, need your advice. (please don't kick me after reading this question)
I wish to increase the acceleration without compromising the top speed.
Calculator inside my mind said go with RX100 sprocket (15/39 instead of stock RXG spec 15/37) This increases the drive ration by 5.43%
Now the calculator made some stupid calculations and said chain the 4th gear ratio same as 5th gear in 5 speed GB spec (22/24 instead of 23/23)
Thanks. No plan for performance upgrade, what as stock as much as possible. Right now using a 15x39 sprockets instead of 15x37 and smoking out all the other bikes (including other RX100s) in signals
Couple of non-OE visible parts were the DCM Toyota headlamp reflector and Minda twin horns, otherwise it is 100% stock
