Chandigarh
Sorry to all members for posting different type of question which is not regarding this thread... i will be careful next time
finally my jopasu duster delievered today. i am shocked to see the size of duster, good length easy to use. Amazon packed it in a huge box and packing of duster is just amazing, fulky satisfied by amazon with the price of just Rs.589 only..
Thanks to Dr.Mudhan and all forum members to told me about this item.
can you please send me the link from where i got WD40 and price of it.
Thread Starter #228
Dr MUDHAN
@ Deep_Chd
Dear, you need not feel sorry, the intention of placing the question at the right thread/place for you to get the right answer from the respective car user/expert.
Don’t buy WD40 online, any good paint & hardware store in your place will have. Please check.
Still want online, it is here: wd 40 WD-40 Multi-Use Product Spray - 63.8 GMS - with: Amazon.in: Electronics
@ Suryaputhra
The bottle may or may not have those marks. Only the fabric will have a label as what kind of fabric cleaner should be used.
I just share with you what I could gather and compile for you!
The Different Types of Upholstery Cleaners
Before you decide which upholstery cleaner to buy, you need to understand the different types of upholstery cleaners and what their labeling mean.
CODE W: WATER-BASED:
Code W refers to fabrics that are man-made such as polyester, nylon, acetate and olefin. These fabrics can be cleaned with Water-based cleaners.
W (water based cleaners): To prevent overall soiling, frequent vacuuming or light brushing to remove dust and grime is recommended. Spot clean using the foam only from a water-based cleaning agent such as a mild detergent or non-solvent upholstery shampoo.
W: Water-based cleaning agents or foam can be used. Only distilled water should be used. Do not use tap water because it contains minerals which can cause rings or fading.
CODE S: SOLVENT BASED
Code S fabrics include organic fibers such as cotton, rayon, linen, wool, silk along with denim, velour, damask, etc. These fabrics should be cleaned with Solvent-based cleaners.
Spot clean using a mild water-free solvent or dry cleaning product. Avoid any product containing carbon tetrachloride which is highly toxic.
CODE W-S : SOLVENT AND/OR WATER BASED
Coded W/S fabrics which can be cleaned with either cleaners. Solvent and water-based cleaning agents such as foam or mild water-free cleaning solvents can be used. However, only distilled water should be used.
To prevent overall soiling, frequent vacuuming or light brushing to remove dust and grime is recommended. Spot clean with a mild solvent, an upholstery shampoo or the foam from a mild detergent.
CODE X : which cannot be cleaned with any cleaners at all.
It should only be cleaned by vacuuming or light brushing to remove dirt. Water-based or Solvent-based cleaning agents should not be used on this type of material. However, in this circumstance, it is recommended that you find a professional upholstery cleaning service.
HOME MADE CLEANERS:
Water-based Solution
1 Fill a clean spray bottle with warm water.
2 Add 2 to 3 drops of mild dish washing detergent to the water, depending on the size of the bottle. Use only liquid detergent, never powder.
3 Swirl the water by moving the bottle side-to-side to mix the solution.
4 Add a capful of white vinegar and 1 or 2 pinches of baking soda to the solution. These ingredients help fight odors. Replace the spray bottle's cap and shake the solution thoroughly.
Solvent-based Solution
1 Fill a clean spray bottle halfway with warm water.
2 Fill the remainder of the bottle with a solvent, such as ammonia, rubbing alcohol .
3 Replace the bottle's cap and shake the mixture vigorously.
Things You Will Need
Spray bottle
Mild dish detergent
White vinegar
Baking soda
Solvent (ammonia, rubbing alcohol)
Tips
Test your solution, especially solvent-based solutions, on an inconspicuous area of the sofa before using it on visible areas.
Never use bleach or fabric softener on microfiber fabrics.
Thread Starter #230
Dr MUDHAN
LEATHER CAR SEATS & MAINTENANCE​
LEATHER SEATS
Advantages
Long-wearing, stain-resistant, odor-resistant, easy to clean, comfortable, luxurious.
A higher resale value for car
It “breathes” better
It becomes softer as time goes by
A unique smell, pleasant for many
More color options and types of leather
Good for smokers as pure leather will not catch fire easily.
Excellent for luxurious, chaffer driven cars as the rich owner need not worry about it at times of car service or for money to replace it!
Disadvantages
Feels hot and cold, more expensive, easily scratched or damaged by pets or other cargo.
Some may not like the smell
Sparingly used & unmaintained car prone for mold growth. High humidity, warm temperatures, and poor ventilation provide the ambient conditions that allow mold growth
Requires absolutely meticulous care, the maintenance is costly and time consuming.
For vegetarians, vegans, and other animal rights activists, leather seats are unacceptable.
Some people who have leather car seat covers take towels or a blanket with them to cover the seats, but this almost defeats the purpose of getting leather in the first place.
MAINTENANCE:
The correct and the best way is first to clean and then condition it by respective dedicated solutions.
CLEANING FIRST:
A pure cleaner should be water based and free of petroleum solvents, silicone oils or gloss agents which will penetrate deep into every pore. It should be applied with a Microfiber Applicator Pad, or a Leather and Vinyl Scrub Brush. Agitation (Not by scrubbing) opens pores and allows dirt and body oils to rise to the surface of the leather where it can be wiped away.
NOTABLE EXAMPLE: 1. Pinnacle Leather and Vinyl Cleaner 2. Wolfgang Leather Care Cleaner
CONDITIONING NEXT:
Conditioners should be pH-balanced and are calibrated to nourish and moisturize. They are engineered at a molecular level, to absorb deep into the fibers' cells, allowing these fibers to retain their resilience, and thereby inhibit premature aging. Proper conditioning allows fibers to retain flexibility and softness.
NOTABLE EXAMPLE: 1. Pinnacle Leather Conditioner 2. Wolfgang Leather Care Conditioner
FOR QUICK DETAILING:
Conditioner and cleaner combination is the second choice.
NOTABLE EXAMPLE: 1. Pinnacle Leather Cleaner & Conditioner 2. Meguiar's G7214 Gold Class Leather Cleaner & Conditioner
Avoid using Inexpensive brands as they leave a greasy finish.
Chandigarh
Hello to everyone,
Please suggest me some car detailing products which are necessar. In my inventory i have Jopasu car duster (purchase from Amazon at just Rs.589), Abro clean cham(chamois leather from local market at Rs.200), Abro car shampoo Gold with wax-2 litre bottle (purchased from local market at Rs.680), 1 piece of Abro microfiber cloth(purchased from local market at Rs.120), Abro Sponge(purchased from local market at Rs.180), Colin glass cleaner,
But i think lot of products are missing, please let me know the products which are essential and from where to buy at reasonable price. Actually im from Chandigarh, lot of shops are here but fake products are in high quantity here. So please tell me where to buy authentic and reasonable products
Hello everyone
I got WD 40 from local shop in chandigarh. It costs Rs.280 for 400ml, this is very effective, thnx Dr. for your advice. After using it the sounds of my car doors are totally changed when i shut them. The opening and closing of doors become very smooth and i used it on all the door hinges, bonnet lock, battery terminals, diesel lid cap lock(sometimes it stucks but now its so smooth), boot lock and in ignition key switch. Really thanks to Dr. Mudhan.
The picture of WD40 is not uploaded, error comes it says that the size of file is not be excedded than 1.0 Mb and the size of my pic is 1.4 mb, what should i do, i'm using iphone, is it any way to sort out this thing
Moga (Punjab)
I got a question for all of you, should i go for DA polisher or perfect my hand polishing skills? I am seeing a lot of swirl marks on my car and i just can't bear them.
Hubli
Hello everyone
WD40 is good for cleaning rust, dust, grease but not recommended as a lubricant.
Once you clean the hinges with WD40, wipe to dry and then apply good quality grease. i.e Bosch Grease.
As of image uploading, you have to resize and/or crop the image and then upload.
AFAIK, by hand its difficult to remove swirls so a machine is the only way to go.
If you can afford DA polisher then it would be worth for you. Not just for repairing imperfections but from compounding to waxing.
Along with DA polisher, you'll need different size backing pads/plates and foam pads. You can find more info posted by me in this thread as well in my Skil 9080 review thread here.
Chandigarh
Hello to everyone
I dont know where to put this queries related to my car, and the other fact is that, the members of this thread are really very good and helpful, so i post this query in this thread. Please tell me how to add friends, from where i send personally message to anyone and sort out my problem. Specially to Dr.Mudhan and Cracing.
May i know your whatsapp contact number from where i talk to you directly.
I have VW Polo, yesterday in chd rain came and i was drive my car, but at a time front glass of my car is totally covered by fog from inside, i had to use AC always to remove the fog or heater according to season. Please tell me if any other way to get quit of fog problem without the use of AC. Have any product or any tip which is used for this problem.
The another problem is related to AC, when i turn on AC, the smell comes for first 2 minutes and after that its normal, i always use air freshner but the weird type of smell comes everytime. Please help me on this to solve the problem
Thane, Maharashtra
Hello to everyone
I have been using proklear anti-fog spray and it worked like charm. You can find more information on their official website Home - PROKLEAR.
In past I had also similar problem with AC when there was foul smell coming in from AC. I had observed that foul smell starts coming if I run only blower without AC. Please make a note that its not that foul smell coming only when only blower was running, I mean to say if I run only blower without keeping AC on then later on I had foul smell. Then I stopped running only blower without AC and I never had that issue again. I always roll my windows down for initial couple of KM journey in the morning to get fresh air inside the cabin. My 2 cents. [:D]
Thread Starter #237
Dr MUDHAN
@ Deep_Chd
Thanks for your confidence in us and I come to the response towards your queries.
1. Regarding AC smell issue please read my article/ post here:
MY ALBUS - HOW I RESOLVED THE MUSTY AC / BLOWER ODOUR!
http://www.theautomotiveindia.com/f...new-honda-city-white-albus-26.html#post379120
2. Regarding windshield glass fog issue, follow what @ bhaveshce suggested.
Anti-Fog Spray for Internal Automobile Glass - PROKLEAR
I remember CRACING also suggested once.
3. Regarding sending personally message, you have already sent me a message so we need not guide you again.
ONE REQUEST TO YOU:
Please post your general queries like this in my primary thread (http://www.theautomotiveindia.com/f...my-new-honda-city-white-albus.html#post321657) and don’t post here.
If anything specific to your car like tire up gradation etc., post in the specific thread so that you will get the best answers.
Dr MUDHAN
Planning second detailing session for my car, last session was in September-2015.
This time I don't want to do CLAY.
Following steps planning to perform, please let us know your opinion.
1. Wash with ONR
2. IPA Wipe Down to remove Existing Poorboys Sealant
3. Apply Poorboys Polish by Hand
4. IPA wipe down to remove polish oils.
5. Poorboys Blackhole
6. Poorboys EX-P
I want to do polish only for cleaning paint, removal of scratches is not priority.
Please suggest me which polish to go for.
1. Poorboys Professional Polish ( non-abrasive, pure polish )
2. Poorboys Pro Polish 2 ( abrasive )
I am leaning towards ( Poorboys Pro Polish 2 ), since it will also remove some minor scratches.
Please note polish application will be by hand.
I am facing a big menance of Bird droppings on my car, normally used to clean them using Colin spray, however, some of them are too hard and I am not able to remove them. Suggestions wil; be appreciated !!
Is their any product that I can use in spray format to clean the car ? I can't wash it, and I know rinse-less wash products help in this but I am not able to decide which one to use.
Use ONR, spray on it, let it soak for one to two minutes than gentle wipe.
Repeat above procedure it it does not get removed in one go.
