Hello Abhishek-
At what speeds you drive usually?
A driving beam is nothing but a slightly wider Spot beam, And It looks very much like your own Factory High beams.
If your current headlights are decent enough in High beam, Get a spot beam. You'll be able to drive faster and safer due to higher illumination distance.
If you drive really fast (130~170 or up) I suggest invest in High-Beam assists. AKA "PENCIL BEAMS".
The higher lamp is Factory High beam.
Notice how wide are factory High beams. And then you can see below HID fogs, the widest. Well you can already see the pencils!
I am not able to judge the beam From pics as the Pics are sideways and also beamshots are not given. It would be better to visit a decor shop at night and check the beam manually. Neolites are also looking good.
