Re: Non-guru's comments
...As I'm new to DSLR, want to take first short of "Deepa" ... (celebrated in TN).
I can connect. My first shot with NEX was Pic of Gods. We are centi, aren't we ?
The first has highlights washed out. 2nd one is a good silhouette. Keep trying. For time being forget PP-ing and concentrate on using histogram and rulers for composing a Pic. Use PP to Crop and add EXIF info. Do not try to enhance your images in PP for time being. If you do so, you would end up learning PP more than Photography and the software more than your Camera.
After posting my earlier one, wanted to try how my method would fare with an everything-all-Kit-Lens. Used Pattern (multi) metering though. Result is below:
The Matchstick was the decoy, that I mentioned. The Pic was taken as I got ready early to office in the morning and the Lamp drew my attention w.r.to this thread. Pic shot at ISO400 didn't come good. I did something wrong, as I've not used the Kit lens that much to understand it.
Pics below were taken today evening using two of my manual focus Prime lenses with manual Aperture control. The next two are an example of getting slightly darker Pics at lesser ISO than jacking up the Ev and darkening later in PP. First is brighter due to ISO1600.
This one below is darker due to low ISO setting. Noise also will be less.
This is a 100% crop of another shot taken at ISO400.
These things are incomplete without one from a 50mm prime.
A 100% crop (I believe) of the flame is below:
Get a classic "
Nikon AF Nikkor 50mm f/1.8 D" lens with aperture control ring. It's available around 6K. Set the D5200 in Shutter priority and start fiddling with aperture on the lens. You'll learn faster and will keep this lens for many years. AND, do not think of investing in many lenses unless you've understood this 50mm at least 80%.
PS: The available light was a single 11W or 14W CFL lamp and the Diya / Deepa lamp.
