DIY Alternator Upgrade of Maruti 800
Sankar, there are quite a few wingers here.Big van kind of vehicles.
It does have a 150amp alternator.Sankar your best bet is the gujri.
You better take measurements of your stock alternator and compare it with the Winger alternator.Also check the pulley.
It is for both safari and winger, missed to put / in between. Hope the info helps.
As jarpickle suggested get the alty from a scrap yard.
Thanks a lot guys. Couldn't find anything in scrapyard in my city. Hard to find in scrapyards in my city as they breakup the vehicle and deal only in certain parts which are commonly sourced
Can you help me find one in scrapyards in your respective cities?
Or else how much will a brand new Safari alternator cost?
Sankar
The price is given there as Rs25735.You can expect it to be close to that
Varun has a few contacts at the scrap yard.Alternatively you can contact SS80(Anand) he should be able to help you out.
Thread Starter #64
You could even try the swaraj aftermarket one which I mention earlier.
It would cost around 12k. Check if it fits.
Does swift diesel equipped with vacuum pump in alternator for brake assistance ?
Swaraj alternator you mentioned has 150amphere ratings right? It costs only 12k? Does it actually provide 150amphere at startup or at particular high rpm ranges?
Sankar
Thread Starter #67
AFAIK, the alternator would not produce 150 amps as soon as it spins.
The alty produces as per the load.
For example - If you are just driving the car, the alty would produce say 20 amps for the engine, another 10 amps for battery charging. Later if you turn on A/C or head lamps it would start producing according to the load.
In swift or any modern cars, as soon as the load is high the engine rmp would slightly increase so that the alty can produce the amount of power required.
Are you sure it will cost only 12k? From where will i buy one?
Sankar
See this website and if you have any sources abroad try to import these.
High Output Alternators and Accessories | PowerBastards.com
What happens if it doesn't fit in my Dzire? This thought is stopping me from importing alternators. If i need to buy from abroad i have lots and lots of options.
Sankar
Lucknow
Sankar
As per the website, this product is for suzuki swift. This is an universal product which will fit in any car.
220AMP Alternator for Imports and Domestics - Fitzall-220 | PowerBastards.com
Also you can contact them and tell about the dimensions of the alternator or about the space available in the engine bay. If they can fabricate a custom alternator.
Sankar, you will need to take your alternator to a TVS shop and check if the Swaraj Mazda one has the same dimensions.
If not you may have to do some mods to get it to fit.They may have something that would fit you perfectly as well.You will have to go to the shop and check for yourself.
@Sankar:You can try contacting:
TV SUNDRAM IYENGAR & SONS LTD
TRIVANDRUM
Neeramankara Karimanam PO Trivandrum - 695 040.
same day cash advanceneed cash fastbest pay day loansadvance payday loanslong term payday loans
STD: 0471
Telephone1: 2491239
Fax: 0471-2491103
Thanks buddy. Will contact him but i have to import them from abroad which means costly shipping charges around 100$ and 37% customs duty for the whole amount including cost of product and shipping. Damn the taxes[frustration]
TRIVANDRUM
STD: 0471
Telephone1: 2491239
Fax: 0471-2491103
Buddy this actually is the showroom of Mahindra & Mahindra in Trivandrum. I doubt if i will find any info on alternators there. But still let me check about them. Will let you know once i contact them.
Sankar
