@jeno, Can you explain something about garret turbo and its implications. what are the direct benefits of "garret"-means how much beneficial w.r.t cost ?
Pls do provide any link or contact of the same if you have.
I do understand some part of it,so my quest is on.
the hurdles are:- somebody should have enough confidence ,enough expertise and patience to carry out such nerving things.I am not enough rich to afford a DIY trial and error yet.
I don't see anything impossible as of now , with kind of technology in hand we can do anything that is my belief.That does not mean I will have to import a new bigger engine(1.6L) and call it a day(let's not be funny here) .
Technical: Fiat JTD Diesel 1.3 engines. - The FIAT Forum
And the above link says 1.9 130HP punto uses Garret turbo at its stock state. And 90HP should be using a VGT turbo i guess which is basically the difference between 75 and 90 hp punto.
But my personal advice would be, changing the turbo is not a good idea, because already your car has a good VGT turbo. If i were you, i would go for a remap/tuning box(not a resistor based one), slightly better injectors and a good filter. Which will give you enough for your daily driving. Expect 120HP from the above modifications.
Jeno
