43. LAMBORGHINI AVENTADOR LP700-4
- Frame: Carbon fiber monocoque with Aluminum front and rear frames
- Body: Carbon fiber engine bonnet, movable spoiler and side air inlets; Aluminum front bonnet, front fenders and doors; SMC rear fender and rocker cover
- Mirrors: External mirrors heated, electrically adjustable and foldable
- Rear spoiler: Movable - 3 positions depending on speed and drive select mode
- ESP: ESP/ ABS with different ESP characteristics managed by drive select mode
- Steering: Steering Gear with 3 different servortonic characteristics managed by drive select mode
- Front tires: Pirelli 255/35 ZR19
- Rear tires: Pirelli 335/30 ZR20
- Front wheels: 19’’ x 9J
- Rear wheels: 20’’ x 12J
- Curb-to-curb turning circle: 12.5 m (41.0 ft)
- Airbags: Front dual stage driver airbag and front adaptive passenger airbag; seats with side “head-thorax” airbags; passenger and driver knee airbags
- Type: V12, 60°, MPI
- Displacement: 6,498 cm³ (396.5 cu.in.)
- Bore and stroke: Ø 95 mm x 76,4 mm
- Valve gear: Variable valve timing electronically controlled
- Compression ratio: 11.8 (± 0.2) : 1
- Maximum power: 700 CV (515 kW) @ 8,250 RPM
- Maximum torque: 690 Nm (507 lbft) @ 5,500 RPM
- Emission class: EURO 6 – LEV 2
- Emission control system: Catalytic converters with lambda sensors
- Cooling system: Water and oil cooling system in the rear with variable air inlets
- Engine management system: Lamborghini Iniezione Elettronica (LIE) with Ion current analysis
- Lubrication system: Dry sump
- Type of transmission: 4WD with Haldex generation IV
- Gearbox: 7 speed ISR, shifting characteristic depending on drive select mode
- Clutch: Dry double plate clutch, Ø 235 mm
- Standard: AMT
- Top speed: 350 km/h (217 mph)
- Acceleration 0-100 km/h (0-62 mph): 2.9 s
