first of all thank u niku and saroya for all the help
no i didn't change the amplifier settings , i asked them to open the doors and interchange the speakers. ie i took the FR speaker and installed in FL. so now do you think the amp is fine ?
i don't think there;s any problem in settings at the amp. he messed up the wiring behind the HU.
so when the first installer was done with the setup , front and rear speakers connection to the amp should be like what you said.
at channel 1 and 2 both front speakers and at channel 3 and channel 4 the rear speakers.
but then when i selected the balance to the left , one left and one right was working so he changed it.
channel 1 front left , channel 2 rear left just like your image ( thanks for taking the time :P )
when i asked the subwoofer guy to make everything as before he also made the same mistake or i should say he did it correctly but the wires behind the HU is to be blamed.
and saroya , i did check the fader settings , when i make the setting to the front , weirdly now the right speakers are more powerful
now channel 1 is FR , channel 2 is RR. and when i keep the balance as L5 , all the 4 speakers have same output.
i will get it fixed after my exams or maybe in 2 days. the same friend just told me he's getting his car done from driven. he's making his promotion car so will go along :P
anyways now i hope you understood everything now.
the pic of the subwoofer. when i opened the boot , the wooden plank on which amps are fixed was lying on the subwoofer.
Your installation was total CRAP, honestly. Get it reinstalled at DRIVEN, even if they say that there's no need, tell them that it is at my cost and they don't need to worry. Do write a negative review (on the forum or elsewhere) to let others beware of that crappy installer from whom you got the setup. Even I get installs done from local guys but I supervise the work (very badly; even the installer gets irritated in some time) and give him a tip before starting the install.
Nikunj
