As The Wheels Roll and The Shutters Click…Travel Reminiscences…
Kerala
Re: As the wheels roll and the shutters click…Travel reminiscences…
Beautiful picture!!! Needless to say...
Though I belong to this part of the country, never had a chance to venture into this destination and activities.
Holding my breath and waiting for your mesmerising images
Thread Starter #47
Hosur/Chennai
Thank you, Ram! Fret not! You will have time to venture into these destinations.
That morning before going on the canal cruise, we went for a walk inside the bird sanctuary. We were told that it was a waste of time going in as there are no birds there.
On the way to the sanctuary we could spot some birds on the roadside.
like this Pond Heron...
this unknown insect...
a Dragonfly...
and some Barbets...
an Oriental Magpie Robin...
a Drongo...
a White-throated Kingfisher...
An Asian Koel (male)...
and a common Butterfly at the entrance of the Sanctuary...
[to be cont.]
Thread Starter #48
Hosur/Chennai
The bird sanctuary is quite small and there is a narrow pathway through the thick growth and tall trees. While we may sight some birds, photographing them may not be possible due to the tree heights, dense growth and lighting. Since the path is also very narrow - we have to walk in single file - it is difficult to move around the bird to get a good composition. We have to walk around 2 km to the end of the sanctuary and back the same way.
As we entered the sanctuary started our walk we were lucky to spot one young Shikra/little banded goshawk. We had this one in our sight for atleast 3 minutes till some people returning back disturbed it. The next bird that we saw was a Racket-tailed Drango, which we had to track hearing its call. Another bird that we saw looked like a male Asian Koel or a Indian Black bird. Not sure though. After coming out we saw a Blue-tailed Bee-eater. Though we have seen the more common Green Bee-eater and the chestnut Bee-eater earlier, this was our first Blue-tailed Bee-eater. Throughout our trip this time we were able to see more of them and take some beautiful photographs of them.
The Shikra (Accipiter badius) is a small bird of prey in the family Accipitridae found widely distributed in Asia and Africa where it is also called the little banded goshawk
The shikra is a small raptor (26–30 cm long) and like most other Accipiter hawks, this species has short rounded wings and a narrow and somewhat long tail. Adults are whitish on the underside with fine rufous bars while the upperparts are grey. The lower belly is less barred and the thighs are whitish. Males have a red iris while the females have a less red (yellowish orange) iris and brownish upperparts apart from heavier barring on the underparts. The females are slightly larger. The mesial stripe on the throat is dark but narrow. In flight the male seen from below shows a light wing lining (underwing coverts) and has blackish wing tips. When seen from above the tail bands are faintly marked on the lateral tail feathers and not as strongly marked as in the Eurasian sparrowhawk. The central tail feathers are unbanded and only have a dark terminal band. Juveniles have dark streaks and spots on the upper breast and the wing is narrowly barred while the tail has dark but narrow bands. A post juvenile transitional plumage is found with very strong barring on the contour feathers of the underside. The call is pee-wee, the first note being higher and the second being longer. In flight the calls are shorter and sharper kik-ki ... kik-ki.
Shikra Juvenile...
The greater racket-tailed drongo (Dicrurus paradiseus) is a medium-sized Asian bird which is distinctive in having elongated outer tail feathers with webbing restricted to the tips. They are conspicuous in the forest habitats often perching in the open and by attracting attention with a wide range of loud calls that include perfect imitations of many other birds. It has been suggested that these imitations may help in the formation of mixed-species foraging flocks, a feature seen in forest bird communities where many insect feeders forage together. These drongos will sometimes steal insect prey caught or disturbed by other foragers in the flock. They are diurnal but are active well before dawn and late at dusk.
In most of its range in Asia, this is the largest of the drongo species and is readily identifiable by the distinctive tail rackets and the crest of curled feather that begin in front of the face above the beak and along the crown to varying extents according to the subspecies. The tail with twirled rackets is distinctive and in flight it can appear as if two large bees were chasing a black bird.
Racket-tailed Drongo... a rear view showing its tail and the streaming rackets.
Indian Blackbird or Asian Koel?
A Pond Heron...
Blue-tailed Bee-eater...
This species, like other bee-eaters, is a richly coloured, slender bird. It is predominantly green; its face has a narrow blue patch with a black eye stripe, and a yellow and brown throat; the tail is blue and the beak is black. It can reach a length of 23–26 cm, including the two elongated central tail feathers. Sexes are alike.
Blue-tailed bee-eater displaying the blue on the tail and rump while perching
This is a bird which breeds in sub-tropical open country, such as farmland, parks or ricefields. It is most often seen near large waterbodies. Like other bee-eaters it predominantly eats insects, especially bees, wasps and hornets, which are caught in the air by sorties from an open perch.This species probably takes bees and dragonflies in roughly equal numbers. The insect that are caught are beaten on the perch to kill and break the exoskeleton. This habit is seen in many other members of the coraciiformes order.
[to be cont.]
Thread Starter #49
Hosur/Chennai
@500 rs per hour, the 4 hour boat ride through the canals was very rewarding. We could see many water birds, Kingfishers, and Bee-eaters.
Little Cormorant...
Pond Heron...
Little Cormorant...
[to be cont.]
Thread Starter #51
Hosur/Chennai
Purple heron...
The purple heron breeds in colonies in reed beds or trees close to large lakes or other extensive wetlands. It builds a bulky stick nest.
It feeds in shallow water, spearing fish, frogs, insects, spiders, small birds, rodents, salamanders, and snakes. It will often wait motionless for prey, or slowly stalk its victim. It tends to keep within reed beds more than the grey heron, and is often inconspicuous, despite its size.
It has a slow flight, with its neck retracted. This is characteristic of herons and bitterns, and distinguishes them from storks, cranes and spoonbills, which extend their necks. The long neck of the purple heron looks particularly snake-like, with more of an S-shape in flight. The call is a loud croaking "krek".
Bronze-winged Jacana...
The bronze-winged jacana breeds in India and southeast Asia. It is sedentary apart from seasonal dispersion. It lays four black-marked brown eggs in a floating nest. The males, as in some other wader families like the phalaropes, take responsibility for incubation.
These are conspicuous and unmistakable birds. They are 29 cm long, but the females are larger than the males. They are mainly black, although the inner wings are very dark brown and the tail is red. There is a striking white eyestripe. The yellow bill extends up as a red coot-like frontal shield, and the legs and very long toes are grey.
Young birds have brown upperparts. Their underparts are white, with a buff foreneck.
The bronze-winged jacana's feeds on insects and other invertebrates picked from the floating vegetation or the water's surface.
Call is a wheezy piping seek-seek-seek given mostly in alarm.
[to be cont.]
Thread Starter #52
Hosur/Chennai
The boatman was good enough to cater to our requests - like stop, reverse, go to this side or that side, turn the boat around, stay still, etc. After one hour of boating, that guy could understand hand signals and slowly began to follow the direction the camera is pointed and maneuver the boat accordingly. It was great having a boatman like that.
Cattle Egret...
Cormorant...
Whiskered Tern... trying to balance on the wire... (we could see plenty of them this trip.)
[to be cont.]
Thread Starter #53
Hosur/Chennai
Apart from the numerous Blue-tailed Bee-eater, we could also see two types of kingfishers in numbers.
White-throated Kingfisher (juvenile)...
The white-throated kingfisher (Halcyon smyrnensis) also known as the white-breasted kingfisher or Smyrna kingfisher, is a tree kingfisher, widely distributed in Eurasia from Bulgaria, Turkey, West Asia east through the Indian subcontinent to the Philippines. This kingfisher is a resident over much of its range, although some populations may make short distance movements. It can often be found well away from water where it feeds on a wide range of prey that includes small reptiles, amphibians, crabs, small rodents and even birds. During the breeding season they call loudly in the mornings from prominent perches including the tops of buildings in urban areas or on wires.
This is a large kingfisher, 28 cm in length. The adult has a bright blue back, wings and tail. Its head, shoulders, flanks and lower belly are chestnut, and the throat and breast are white. The large bill and legs are bright red. The flight of the white-throated kingfisher is rapid and direct, the short rounded wings whirring. In flight, large white patches are visible on the blue and black wings. Sexes are similar, but juveniles are a duller version of the adult.
[to be cont.]
K L-9
Those are some pictures indeed !
We do have quite a lot of bird species around. Driving through villages in Kerala is lot of fun. I do get to see lots of birds and hear them singing and calling almost all the time. This one, a kingfisher shot at water body near my home in Kerala yesterday.
A down sized copy of the image here.
Thread Starter #56
Hosur/Chennai
I am fan of your awesome photos [:)]
Thank you, alfa alfa![:)]
i have been one of the regular visitors to this thread. Its absolute delight to watch, what you capture in that miracle box of yours. Just stunning, Mind Blowing BOOM!!!!
Thank you, incarnation![:D]
Darter/Snake bird...
The Oriental darter or Indian darter (Anhinga melanogaster ) is a water bird of tropical South Asia and Southeast Asia. It has a long and slender neck with a straight, pointed bill and, like the cormorant, it hunts for fish while its body submerged is in water. It spears a fish underwater, bringing it above the surface, tossing and juggling it before swallowing the fish head first. The body remains submerged as it swims, and the slender neck alone is visible above the water, which accounts for the colloquial name of snakebird. Like the cormorants, it has wettable feathers and it is often found perched on a rock or branch with its wings held open to dry.
[to be cont.]
Thread Starter #58
Hosur/Chennai
Purple Swamphens...
Purple swamphens are generally seasonal breeders, but the season varies across their large range, correlating with peak rainfall in many places, or summer in more temperate climes. The purple swamphen breeds in warm reed beds. The male has an elaborate courtship display, holding water weeds in his bill and bowing to the female with loud chuckles. In the western parts of the range the pattern of social behaviour tends to be monogamy, but cooperative breeding groups are more common in the eastern parts of the range. These groups may consist of multiple females and males sharing a nest or a male female pair with helpers drawn from previous clutches.
The purple swamphen prefers wet areas with high rainfall, swamps, lake edges and damp pastures. The birds often live in pairs and larger communities. It clambers through the reeds, eating the tender shoots and vegetable-like matter. They have been known to eat eggs, ducklings, small fish and invertebrates such as snails. They have even been known to attack large eels, however there is no consensus amongst ornithologists if they actually eat eel. They will often use one foot to bring food to their mouth rather than eat it on the ground. Where they are not persecuted they can become tame and be readily seen in towns and cities.
Evidence from Pliny the Elder and other sources shows that the Romans kept purple swamphens as decorative birds at large villas and expensive houses. They were regarded as noble birds and were among the few birds that Romans did not eat.
[to be cont.]
Thread Starter #59
Hosur/Chennai
And then we saw this Blue-tailed Bee-eater perched in a beautiful spot. As the boat moved past the bird, we could take many beautiful pictures of this lovely bird with changing background. The intense look and the background hues make this bird very special. Surely this bird will find a place in our next year calendar. [:D]
[to be cont.]
Thread Starter #60
Hosur/Chennai
We had lunch at a lake side restaurant that the boat man took us to. We had Lobsters and Pearl spot fries. The food was below average, unlike the food we had during the boat cruise in Alleppy last trip.
a pair of Drongos...
A Snakebird and a dozen Cormorant resting...
Egret in a hurry...
Stork-billed Kingfisher...
This is a very large kingfisher, measuring 35 to 38 cm in length. The adult has a green back, blue wings and tail, and grey head. Its underparts and neck are buff. The very large bill and legs are bright red. The flight of the stork-billed kingfisher is laboured and flapping, but direct. Sexes are similar.
The call of this noisy kingfisher is a low and far reaching peer-por-por repeated every 5 seconds or so as well cackling ke-ke-ke-ke-ke-ke.
Stork-billed kingfisher is a species of a variety of well-wooded habitats near lakes, rivers or coasts. It perches quietly whilst seeking food, and is often inconspicuous despite its size. It is territorial and will chase away eagles and other large predators. This species hunts fish, frogs, crabs, rodents and young birds.
Stork-billed kingfisher digs its nest in a river bank, decaying tree, or a tree termite nest. A clutch of two to five round white eggs is typical.
[to be cont.]
