Air Cabin Filter
Thiruvananthapuram
Hi Libran,
I would suggest that you go to the Sector 28 Car market and get it from there. The filter is nothing but Cellulose paper structured in the form of Fins and glued together in a square Cardboard. The service centre will unnecessarily charge you too much for the simple filter.
When I bought the filter I was shown two filters one for Dzire and the other for Swift .... both were exactly of the same size and material however the Filter for the Swift was of Rs 300 and that of Dzire was for Rs 400. I took the one which was for Swift and saved Rs 100 and it was a perfect fit.
After seeing what the filter is I believe that actually it should not even cost 100 Rs.
I am actually looking for a Cellulose Air Filter Paper or a Foam based Filter(It is washable) and next time will do it as DIY project. No point in paying 300 to 400 Rs for a simple thing like this
Thanks
Sunil
Please go for MGP it only costs 300-400 range, filters are cleaned very often not changed.
Chandigarh
Hi Libran,
Thanks
Sunil
Thanks Sunil for your valuable suggestion. I will surely look for this in Sector 28.
Thread Starter #35
Noida/Chandigarh
It is not necessary to buy MGP from the dealer itself,Maruti has started MGP outlets,if you know to install you can save the labour charges.
Yes you can if they at all keep these filters Usually you won't find .... even I tried in the whole of Noida area and there are two MGP outlets but they did not have it .... when I asked for the cost they told me it would be around 500+ Rs.
Actually you need to be smart at to what you want to do from Maruti Service centres like I never go for wheel alignment or wheel balancing from Maruti Dealers I always get it done from outside (Good Year or Michilin Shops) as it is a lot cheaper . but then for the normal service I always get it done from Maruti ...after all it is an individual person to judge what he want's to do from an authorize service centre
Thiruvananthapuram
Buddy, down here we have many outlets and these are opened by maruti to help us with the MGP as the dealers are not authorized to sell the spares,and it is an effort on maruti to ensure all maruti vehicles run on MGP though it is not possible.
Good local workshops only prefer MGP (on some specific spares) as they are concerned of their goodwill, on repeated efforts of these kind of people resulted in these outlets,
And for your information there is an order book placed at all MGP outlets where you can place order on any maruti spare and it will be delivered in a very short period of time as the spares are in prodution.
And as you said its ones will to use Genuine spare or the seconds.
On alignment and balancing what you are doing is apt,as the dealers wont spend time on aligning and balancing(even though they are charging) they will rotate for sure,it is because they have a target on service a day and the target is a bit high.
