Even this could be if the driver door open. At my garage today its hand break was turned on and the driver side door was open. I start but it didn’t, I was surprised as the car was in neutral, then tried again but no luck. Then close the door and put the hand brake off and its start. I will check by the door open tomorrow.
Another thing I noticed, if the car is locked and you unlock by the remote and don’t do anything, after a few second the car get lock again by itself. I observed this only once.
Also like Nick said, there have no button beside the rear camera to open the hood, I checked very carefully. Where I saw the switch in earlier models it’s a flat plastic cover there. I think probably its in SX(O) only or its removed for the new model.
And one bad thing I noticed, while refilling air I tried to check the 5th wheel but it was turned inside and without removing it one cannot fill/check the air. And I couldn’t as I was in hurry. Don’t know if its same for alloys.
The Bluetooth get connected by itself if within range and the phone BT is active, it works smoothly with my Galaxy S.
Also I don’t know how the headlight angle adjuster works, while driving I tuned it from low to high but didn’t see any effect. What is its purpose?
