Does it show any abnormal behaviour now? If not, go for the next upsize piston. Proper resleeve job can match the performance of unsleeved bore.
Don't fix something that ain't broken.
Yeah, I dont see much impact on the performance, but little noise on low speed. I'm thinking its clutch noise, as i adjust the clutch lever the noise reduces and on high speed too. But with that adjustment, i hardly left with limited ply on the lever.
And in i feel missing little low grunt. Once the machine is on power band, i can see it all doing good !
Probably we will meet once, as im staying near Pallavaram only. :) Will PM once i get access to it.
90% of mechanics will not do the re-sleeve better. I am having 2 RX100's and i went to many Mechanics around the Coimbatore Siddhapudhur area. Yes, i too saw some 2 to 3 bikes which was re-sleeved and running in a good condition. But they are not rough riders.
If possible try to get any bore, else if you find your Mechanic is capable to do this Resleeve better, then go ahead.
Tuning is another part where i felt exhausted and finally i got it done from a retired mechanic. Actually he called me on hearing the miss beat of my bike and told me to come to his home. I went and he took around 40 minutes and Once done, it was totally different. Thing is, If you ride RX in 60 to 70 kph and take the hand from acceleration, till the bike reaches 10 kph it should release the next beat. From 70 kph to 10 kph, it only sing the humming, not even a single beat will come until it reaches 5 to 10 kph.
So there are many things which need to be seen while reworking the RX100, since its one of the GEM of an engine where you hear a wonderful beat (Racing sound).
Hope Mr.BOSS can support you with guidance.
Thanks for your guidance Ambylovers. Not sure whether my mechanic is much capable, but he is doing good work on RX. He too owned a one in good condition (RX135 5S), and recently sold ! Probably i may need to meet Mr. Boss, and have to proceed further on this.
With the more information as you guys share, i do learn more and more, would eventually help on doing better restoration job :)
