hi Thanks for your reply i will check that for sure can you let me know what will be approxmimate cost for restoration i need some good mechanic in chennai who does these
kind of things will lot of care i have asked other members also hope i get some help soon
Full & proper restoration will cost you upwards of 40k. If you are on tight budget, do it in stages,
Stage 1) Mechanical Upgrade (Engine, transmission, brakes, etc) + Basic electricals + Frame painting (strengthening, if required) + New / Better Tires
Stage 2) Cosmetic Upgrade (Painting, plating, new lamps, etc)
I would suggest not to depend on mechanics, do yourself as much as you can. And don't fall for the fancy words like 'power piston', 'imported parts', 'performance parts', etc. Unless you are into drag racing, genuine Yamaha parts should be more than sufficient.
