Zen is Stalling Frequently - Help Required (Resolved).
Thread Starter #91
Re: Zen is Stalling Frequently - Help Required.
Update : Yesterday done trip from Pune to Nashik and Back - around 500 km
The cars performance was excellent. No heating observed and now it is feeling more smooth.
CNG mileage : 26-27 km / kg
Thread Starter #92
Good to hear that your car has returned to its usual self.
Take proper car of your car and treat it right.
The car gives you all the signals before it breaks down, so listen carefully.
Thread Starter #94
Yes will do that for sure.Thanks a lot for your help.
Thread Starter #96
Facing a new issue now. The coolant is getting sucked rapidly.I have topped it 4-5 times but same problem persists. Checked the tank for leakage but it looks ok to me. Now don't know what is the cause. Any idea?
Get it checked with a mechanic.
A few things you can try, check the color of the oil if its white you know the coolant is mixing with the oil.Check the rubber pipes to and from the radiator.
Do visit a mechanic and see what he has to say.
Thread Starter #98
Thanks jarpickle, I will check this, yes will visit the service station tomorrow.
First the coolant tank cap was broken which I git replaced. This cap is having 2 openings, is it ok?
The opening is for air to escape out.It should be ok.As long as the coolant isn't coming out from the top it is ok.Try not to fill it to the cap but to the markings given on the overflow tank.Between low and full.
Thread Starter #100
Yes, done the same. The car is now running fine, hence I haven't visited service station. I am keeping eye on temp gauge while driving and also check the coolant level 4 times a day.
