Dear Folks,
As a first step, mechanic removed the existing 2WD gear box from the jeep
Also, at the same time, Mechanic removed the 4WD gearbox from MM540.
So, Removed Rear Right Aligned Housing from the Willys and tried to do a modification by giving it in lathe to make it left aligned.
Resulted in Failure. Since, it needs a complex modification and may end up with misalignment. So, dropped the Idea of modifying the left aligned rear housing to right aligned.
Finally, removed the Old Jeep’s Rear housing which is already left aligned..
