I am a Punto 90HP owner, and I would like to confirm that following POINTS are untrue.
#3. Punto does not come with Hydraulic engine mounts! I know this because I had all three of mine replaced under warranty and they were rubber. Mine is a 2012 model, dont know if they came on the previous models. However, Palio came with those.
#23. Speed sensing Headunit/volume control is a SHAM!!! ~ Its cost cutting that appears like a feature to us, SAD!
Its got to do with the Tiny 55AH battery they give you as OEM. Replace this batter with a bigger 65AH, the one that comes in swift, and you will see this disappear magically.
#24 speed sensing wipers is a SHAM too! ~ Its cost cutting that appears like a feature to us, SAD!
Again once you replace your stock 55AH to a Fiat recommended 65AH and this will be gone for good.
In the higher RPMs the alternator produces more power hence you get louder audio and faster wipers.
You can check it out while the car is at stand still too, rev the car past 2200 rpm and see the wipers going faster and music getting louder and once its back to idling it slows down and mellows down too respectively.
#20 I couldnt get my punto to have one parking light lit with the indicator stack.
