Under Car Neon Lights
The Alternative to drilling holes is Using 3M double sided tape.
The surface needs to be cleaned well and once stuck really well, it will not drop down until your forcibly pull it with all your force.
I've used 3M tape, the cost is on the higher side but is totally worth it.
napster
AP-09
Hey Napster how much does branded cost??
Neil has said that branded tubes only cost 4k for all four sides!!
Branded ones cost around 7500 if you go for streetglow.
@Napster, can you kindly post a picture of the Neon's mounting on your car?
I'll post the pic once my car is back from washing, Car is completely dirty from the bottom so once its done with a wash I'll be able to click pics of the mounts
Can we use some other adhesive, like quickfix etc.?
Not really, Nothing can hold these tubes better than a screw. If you have provision, Then you can try fixing the tube with the help of a wire.
Hey CoolDhaya!
You can get it Car Jewels, Anna Nagar.
But they dont prefer Neons as they burst easily.
Neons easily tends to break in our road conditions.
LEDs are the only alternate sourc which everyone recomends.
They can be used in any road conditions & even in rain & a cheaper option too.
Thread Starter #28
Any alternatives for Neons?
Any idea about the pricing of LEDs?
Am not sure about about the pricing of LED's but i heard its very much cheaper than the neons!!
LED's look cheap.
They don't spread the way Neon light does.
They give spot kind of things below.
