Turbo Intercooler
Bokaro/Bangalore
I will check in my Punto tomorrow what happens in idle if AC is switched on. Default idle RPM is little bit less than 1K (around 900).
In Punto it remains same. I checked just now. It increases very little, hardly you can notice. May be from 900 to 905.
Bokaro/Angul
This, actually is a very good thing. The rise in rpms is because of the additional load on the engine. As the ac is switched on, load increases, and idle rpm decreases. To compensate this, ECU increases the idle. Most of the times it is over compensated, as in cooldhaya's verna. The negligible increase in your punto shows the attention to detail.
[cheers]
